Question about Canon PIXMA iP3300 InkJet Photo Printer
Black ink cartridge
Since replacing my black ink cartridge my printer will not print the black portion
  • dory_duh Mar 13, 2009
    yeah mine wont work either. i replaced the ink cartridge and it now wont print black. i have cleaned the printer heads and it still wont print. this has happened before and i had to get a new printer and i dont want to have to do it again!!
    Problem Solver:
  • 5 Answers
Print head maybe blocked and needs cleaning.
I stumbled on an ebay seller who is selling cleaning solution for print heads. Canon print heads are removable without special tools.
I gave mine a clean with metho, as I figured that it could not get any worse and I got the gist that I was going to have to replace the printer anyway.
I cleaned it with metho (just the bottom of the print head) and ran the clean print head function twice from maintenance and it is not working perfectly.
I do recommending taking this advice with caution as I do not know if this process could cause further damage or not work.
Posted on Nov 28, 2009
  • 1,800 Answers
Try clean the cartridge nozzles and printers ones aswell.
Posted on Jan 03, 2009
2 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: new cartridge won't print
  1. Make sure you removed the tape from the ink cartridge.
  2. Press the <Menu> button on the printers operation panel.
  3. Press the left [<] or right [>] arrow buttons to select [MAINTENANCE].
  4. Press the <Set> button.
  5. Press [<] or [>] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  6. Press <Set>.
  7. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 26, 2008
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
OR
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
Brother mfc printer will not print black ink
Sounds as if the black portion of the printhead has dried or become blocked. I would advise running cleaning cycles from your printer software or the printer itself (should be tucked away in maintenance/ink management).
If this fails to help then unfortunately it is likely to be a mechanical problem with the printer itself. In which case I would recommend getting in touch with Brother themselves for repair/replacement.
Nov 07, 2012 | Brother Black Mfc J 615 W Compatible...
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
The black ink cartridge is not empty but it won't print anything black. Will print colors.
Probably your ink cartridge is clogged. Try to clean it first by using your printer cleaning software. If it does not work, take out the black cartridge clean the portion where the ink is coming out using a cotton and a cleaning solution (water and alcohol will do). Repeat the procedures if necessary.
May 12, 2010 | Lexmark X2600 InkJet Printer
Streaking effect during printing Officejet 7130
As you have replaced the both cartridges and still the issue persists, then this is a hardware issue with the unit. Please repair your printer.
:) Dr Tony
Apr 14, 2010 | HP Officejet 7130 All-In-One InkJet...
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
My printer does not print
If there is no black in the test page then there is the problem with black cartridge .then try these steps
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Feb 14, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
I have a Canon Pixma IP 5000 inkjet printer and am using Mac OS 10.3.9. It has 5 ink cartridges: 2 black (3e and 6) and one each yellow, magenta and cyan. I use it all day every day. After printing...
Thanks for getting back to me.
Sorry this ain't a solution but it seems to be the only cash-free way to contact you. No problem not solved - though I have tried everything. Dismantled the printer; washed, dried and replaced the waste ink pads; washed the print head; blew compressed air through the print-head sponge; replaced the cartridge 3 times; printed hundreds of test prints. I can't think of anything else to do and so I think the only solution is to replace the printhead (probably not even available) or replace the printer. The latter is looking most likely.
Feb 10, 2008 | Computers & Internet
Canon PIXMA  iP3300 InkJet Photo Printer Logo
211 people viewed this question
old marine
old marine
