Question about Garden
Not getting oil on the bar - Garden
  • Garden Master
  • 14,363 Answers
Your oiler is clogged up,remove chain and bar and clean oiler.
Posted on Oct 30, 2012
My ***** 450rancher doesnt seem to be getting bar oil to the bar any sugg.
yes it can become plugged but what concerns me is that you said you just changed your bar. If you didn't get the right bar the oil holes will not line up thus no oil getting thru or you may have an adjustable oiler that's not set properly
Nov 04, 2014 | Garden
No oil lubrication at chain or bar.
There are a couple of things to check. There is a small hose that runs from the bar oil tank to the bar. This may be clogged or cracked so that no oil is getting to the bar. I would also check the "O" ring on the bar oil tank. Of this is bad the tank can't pressurize and the oil won't flow to the bar. You may also want to check and see if all the little hoses to and from the bar oil tank are in good shape and connected.
Regards Outback
Apr 25, 2011 | Poulan Pro Chain Saw 46cc 20"
Excessive bar oil coming from clutch area.
Is bar oil getting on the chain? Depending on the model, their maybe an adjustment on the oil pump to control the flow, check the owners manual. Also make sure you are using bar and chain oil as regular motor oil is much lighter and tends to get "flung" off more.
Feb 16, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
No oil to bar
Remove the nuts that hold the clutch cover on, Then remove the bar and chain. Make sure the port hole in the bar is open for the oil to flow into the chain groove. The oil ports can get plugged by sawdust and chips. Bar oil is sticky. The bar and chain should be removed and cleaned on a regular basis. Clean the groove in the bar too. Also make sure the port on the saw body is open. Start the saw with the bar and chain removed, if oil doesn't flow from the port, then you have a faulty oil pump and will need to go in deeper to replace the pump parts.
Always use proper clean chainsaw bar oil. Using other types of oil can burn up your oil pump.
Dec 27, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
No oil is getting on chain. I cleaned the chain saw and especially the bar and bar groove, but still no oil getting on chain. Is there a hole that I can stick a wire in to make sure it's not plugged ?
Remove the bar and chain (release the chain brake first) and clean the side of the engine case where the bar fits to. Start the engine and observe whether oil oozes out of the side port. If ok, clean the small oil passages in the drive end of the bar that run out to the chain groove on each edge from the large holes. If no oil came out, then the oil pump, oil line, or oil tank filter may require service. Good luck!
Dec 08, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Cant get oil plug loose
FIRST: oil the plug (I know it sounds redundant)
1. breaker bar instead of ratchet wrench (buy one if you dont have one)
2. extension bar on breaker bar handle
If Getting desperate:
1. buy a new oil pan plug
2. use a damaged/rounded extraction socket on a breaker bar.
3. use an extension handle on the breaker bar handle
Be prepared to buy (and install)a new oil pan if the threads on the oil pan are ruined.
Installing a new oil pan is "easy" for experienced mechanics, but
replacing one can be involved for 1st-timers - and you'll usually want to buy (and install) a new oil pan gasket with the new oil pan.
That's everything from breaker bar (your minimum for stuck bolts) to replacing plug and pan (the worst-case scenario).
Sep 21, 2010 | 2006 Chevrolet Monte Carlo
No oil to bar
The first thing to check is to see if the oiling hole in the bar is clear of sawdust a debris. Remove the chain and bar completely and make sure the holes are clear. While the chain and bar is off you can CAREFULLY run the saw to see if oil is coming out if the pump. In some cases you need to remove the tin shield that is behind the bar and clean out the oil passages in there.
Jul 23, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Problems with the 350 husqvarna bar.
If all you say is true and when revved up the saw oozes oil with the bar removed, then I suspect the bar is incompatible with the saw. Has the bar been replaced? The oiler holes in the bar must align with the channel in the saw. Oiler hole placement is part of the reason there are so many different part numbers for bars. The mount is only part of the requirement.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Husqvarna Forest & Garden #952802239 235E...
Stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
Apr 14, 2009 | Garden
Bar sprocket smokes, gets hot spot
Sounds like you're not getting enough oil to the chain. Basically you've got an oil pump, pickup and filter involved in getting oil from the resovior to the chain/bar. If you cleaned the obvious area and the chain is not coated with oil, you may have a clog further up (inside) the oil delivery mechanisms. Also, drain the oil from the tank, and see if you can "blow" air through there. With the saw running & pointed down, you should be able to see oil on the ground being slung off the chain, if not, you are not getting enough oil to the chain.
Nov 29, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
