Question about Janome 6019QC Mechanical Sewing Machine
Always thread breaks
Thread in the machine while working it breaks
  • Janome Master
  • 7,365 Answers
Try these suggestions
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Posted on Oct 30, 2012
Serger machine not braiding
Remove all the threads from the machine.
Be sure, when you thread the machine, you ALWAYS RAISE the presser foot. Also when threading from the thread tree down through the tension disk, give each thread an extra little tug to make sure it is seated.
Always thread each thread in the order specified. Threading out of order will guarantee failure. If a thread breaks, start over with no thread in the machine.
Jul 27, 2017 | Sewing Machines
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Mar 16, 2017 | Sewing Machines
Lower looper cotton keeps breaking
Usually it means it is not threaded correctly. Remove ALL the threads from your machine. Be sure you RAISE the presser foot when threading. ALWAYS thread in the correct order. Verify the thread path for each is correct. Check that the threads are seated in the tension disks--give each a little tug when going through the tension disk. Be sure that the thread tree is extended to its full height. Check that the lower looper threads are not set too tight. Also, always use fresh thread--no old stuff from grandma's sewing basket.
ONE MORE TIP: When a thread breaks, you will usually find it less frustrating to unthread the ENTIRE machine and start from scratch. Trying to fish a thread out of sequence will most often times end in failure.
https://help.brother-usa.com/app/answers/detail/a_id/123258/~/lower-looper-thread-break
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
Jan 15, 2017 | Sewing Machines
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Why Does My Top Thread Keep Breaking Sewing Machine
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
My thread keeps breaking when I sew
Tension is maladjusted. There is a tensioner on the front of your machine. If it is too tight (turned clockwise) the thread will break. Also could be the bobbin has tangled. Remove it and check for tangles.
Aug 18, 2012 | White Sewing Fashionaire Sewing 2380...
The thread breaks a lot when sewing.
Use a good brand of thread and not old or cheap thread.
Thread as indicated in the manual (always with the presser foot up).
http://www.singerco.com/accessories/manuals.html
Mar 17, 2010 | Singer 7430 Sewing Machine
I can start working withmy baby lock, the needle brokes verytime i runthe machine , and i can not sew
If this machine has a needle position adjustment and it is on the center position -
and you are sewing a zig-zag stitch and using a presser foot with a narrow opening this could break the needle
and the needle plate is a single hole, this will break the needle.
and you are sewing a straight stitch with a new needle and it breaks, the machine needs to go in for servicing.
Feb 13, 2010 | Baby Lock Sewing Machines
Janome 6019QC Mechanical Sewing Machine Logo
153 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
