Question about Singer Touch Sew 7462 Mechanical Sewing Machine
Singer touch & sew 7462 adjusting bobbin tension
The bobbin tension is non-existent, how do I adjust it
  • Singer Master
  • 7,365 Answers
Try this link for a manual, it should show how to adjust the top and
bobbin tension.
http://www.singerco.com/uploads/download/466_7462_efs.pdf
Posted on Oct 30, 2012
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
kent581
  • 87 Answers
SOURCE: Bobbin tension on Viking 350 Sewing Machine
Viking bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Posted on Mar 19, 2009
  • 96 Answers
SOURCE: My bobbin thread keeps getting tangled and
there is a screw on the side of the bobbin case, which needs to be turned to the left or counter clockwise to loosen the tension and also change the needle because a burr on the end will cause problems with bobbin thread
Posted on Dec 13, 2009
  • 36 Answers
SOURCE: can't pick up bobbin thread
Unfortunatlly if it will not pick up thread, it is possibly out of time. But before you go changing the timing, make certain it is threaded correctly, the bobbin is threaded correctly. If they are all good see my tip on time a sewing machine.
Posted on Jul 20, 2010
SOURCE: how to thread the bobbin on a singer touch and sew model # 625
how to wind the bobbin of the singer touch and sew model 625
Posted on Jul 26, 2011
I have a 2013 Singer one plus that I bought less than a year ago. My bobbin case keeps locking up. After I take plate off & take out bobbin case then put back in correct position & sta
Could be that your bobbin thread is wound too tightly and having a problem pulling thread from it. Try setting the pressure on bobbin a bit less and that may cure it.
Sep 30, 2014 | Singer One Plus Computerized Sewing...
Sewing machine tension
here is a link for a free manual,, it should show how to adjust the
tension on the sewing machine
Oct 30, 2012 | Singer Touch Sew 7462 Mechanical Sewing...
Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
Jul 29, 2012 | Singer 3820 Mechanical Sewing Machine
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
I am sewing on demim. The thread is inches loose on the back side... it is terrible. Not really sewn at all. I have changed the tension on top several ways but it does not seem to make a difference. I...
The manual can be downloaded for free from Singer's web site...
Are you seeing loops of the upper thread on the bottom side? If so, then the bobbin tension is too tight, or the upper tension is too loose. The threaded shaft on the upper tension might have stripped, leaving you with no adjustability.
Sep 16, 2008 | Singer 7462 Mechanical Sewing Machine
How do you change the belt on a Singer 7462?
By removing the top cover, or the turning wheel cover,
you will be able to see the belt.
If the belt is not broken, then try to adjust the belt tension,
by adjusting either the height of the motor, or the tension wheel.
May 28, 2008 | Singer 7462 Mechanical Sewing Machine
Bobbin
To adjust any sewing machine for thin material do the following.
1.Use a fine needle,
2.Use a fine thread,(upper & Lower)
3.Reduce the the thread tension, Upper& Lower)
4.Reduce the presser foot tension,
5.Reduce the stitch Lenght.
6.Help the machine by pushing the material towards the needle while sewing. (don't pull it back.)
Apr 04, 2008 | Singer 7462 Mechanical Sewing Machine
Singer Touch  Sew 7462 Mechanical Sewing Machine Logo
289 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
