Question about Digital Concepts Digital Camera
Digital camera will not recognize sd card its says its protected
  • 2 more comments
  • jdam3 Jan 03, 2009
    lock is off
  • Anonymous Feb 03, 2009
    my camra is doing the same thing
  • nettiecocane Feb 13, 2009
    my camera says protected card when i try to erase or take pictures
  • julie9876 Mar 16, 2009
    I had the same problem
    Problem Solver:
  • 8 Answers
Take the card out some times it has a small lock button on the card make sure that lock is off
Posted on Jan 03, 2009
When i switch on my digital camera write protect message is displayed on it , my camera is olympus fe-190
If your camera uses a SD memory card then the write protect switch maybe on.
SD and Micro SD memory cards has a smallslide switch on the edge of the card, which write protects data on the memorycard. Slide the switch from the READ position tothe WRITE position, which is furthest away from the contacts.
May 06, 2012 | Olympus FE-190 Digital Camera
What memory card do I buy for my Kodak easyshare C530 camera.l The one I purchased was a SD card and it would not allow me to format.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7551/7269&pq-locale=en_US&expression=sd
The above link goes to a site that describes how SD or SDHC cards can be used in newer C cameras such as yours.
Also, the following should be noted regarding sd cards:
Question : Why doesn't my camera recognize the SECURE DIGITAL (SD) or MultiMedia (MMC) memory card that is in the camera? Answer : Your camera may not recognize the memory card inside for one of the following reasons:
  • The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
  • The card may be corrupted. Reformat the memory card.
    CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
  • The card may not be a certified SD or MMC card. Purchase a certified SD or MMC memory card.
See your camera's user manuals for more information. Go to KODAK Product Manuals, and select the manuals you need.
Jul 26, 2010 | Kodak EasyShare C315 Digital Camera
Doesn't recognize memory card. I had an Eye Fi wireless memory card installed and now it's totally blank and the camera doesn't recognize it. Tried a regular SD memory card, and the camera doesn't...
Your camera is only supporting SD/MMC Cards (up to 2 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 23, 2010 | Kodak EasyShare Z740 Digital Camera
Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
Oct 20, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My Fuji digital camera model Finepix Z20 is showing a protected card message when I insert both my old SD card and my new SD card. My old SD card was working fine yesterday but now it says protected c
Good day,
This is a common problem that many people experience with their SD Cards.
It is normally an easy fix and you can follow a method that I posted on my tips here:
http://www.fixya.com/support/r7042428-sd_card_write_protect
Please feel free to let me know if this was helpful!
Regards
May 06, 2009 | Fuji Finepix Z20fd Digital Camera
Snap Shot Pixtreme 3.1 M camera corrupts SD cards
If you just put the card straight into the card reader, not forgetting to set write-protect, you should eliminate this problem.
Aug 04, 2017 | Snap Sights SS 1.3 Digital Camera
Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
May 26, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Card Error
If the memory card is not recognized in the PC or it is impossible to access the data on it, the controller on the card is damaged. There is only one way to get the data back, unsolder memory chips and directly access their raw data with a programable chip reader. Software can't help, that is a physical damage! Have a look at: http://card-recovery.biz/us/service.php
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Camera doesnt recognize a Secure Digitalor MultiMediamemory card?
The cause and solution may include one of the following: The card may not be certified SD or MMC. Purchase a certified SD or MMC memory card. The card may be corrupt. Reformat the memory card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Digital Concepts Digital Camera Logo
42 people viewed this question
Top Digital Concepts Cameras Experts
Robert
Tony
Are you a Digital Concepts Camera Expert? Answer questions, earn points and help others
