My new hp flash drive used space empty, free space empty,
A few important bits of information about using faults and fixes on usb drives click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP Right click the icon of your Flash Drive (It should be F: / E: or something) if you need more help with this post a reply
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see
click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box
(I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive
also you might need to do this
also
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps
SOURCE: I have a 2006 HP Pavillion PC main process: AMD
The short answer to your question is "Yes" however, all information on the drive would be lost. As a work-around, store/move more information to the D: volume. Perhaps install any new software programs to D: rather than C:
SOURCE: cannot copy items to flash drive because not
if ur flash drive is new then it might be of fake quality .try to confirm from product support that ur item is the original one or not and if not get a one.
Check this also might help/ The other Way is try to format ur flash drive if unable to format then restart pc and then format if unable to format then use this tool
use this utility link:
http://en.kioskea.net/telecharger/telecharger-127-hp-usb-disk-storage-format-tool
install this then connect ur flash drive and restart pc then format by using this tool.
SOURCE: My 1TB HP simplesave hard drive is not working
i have the exact same problem..... where you able to fix yours?
SOURCE: my pen drive is of
Insert the USB stick in your computer, then go to "Start" then "My Computer", locate the USB icon and right click and select "Properties". From there you can do a format of the stick. This will erase all the data including some hidden files that you might have and solve the problem.
Note that even though it says 2Gb, the data you can use is slightly less. This is true for any storage device out there.
