Question about Asrock K7VM4 Motherboard
When i burn cd or copy paste something or during playing games a blue screen comes saying physical dump of memory?plzzzzzzzz anyone give me solution.
  • Chip Loon Ng
    Chip Loon Ng May 11, 2010
    Hi vikee_01,
    Welcome to FixYa!
    Can you give us the error message that you have come across?
    At the end of the blue screen, you will see 0x00000xxx(xxxxx,xxxx,xxx,xxxx).
    Please give us the information, so we can help you.
    Thank you.
    Problem Solver:
  • 7 Answers
Its probably because of Ram Check your Ram and make sure its good or Replace with new how long you using your systm
Posted on Jan 04, 2009
    Scholar:
  • 40 Answers
There seems to be a memory problem on your PC, you might need to replace your memory modules, please check if you have low latency memory since that type of memory needs a voltage adjustment made in the motherboard startup Bios to work correctly.
But first you can try opening windows CONTROL PANEL / SYSTEM look at the ADVANCED tab and click on the SETTINGS button at the STARTUP and RECOVERY section, a new window will pop up and select (NONE) at the WRITE DEBUGGING section in that window. And see if it gets better, if not try deselecting the 3 options above this write debugging section. All this is safe to do, if it works it works, if it doesn't nothing happens.
Posted on Jan 03, 2009
Physical memory dumping when l start to play gta
providing the actual dump message will greatly increase the chances of a correct diagnostic of the problem. (yes the message actually tells us why it goes to physical mem dump) other than that i'd check the fans and fins for dust buildup (causes overheating)
Nov 02, 2013 | Rockstar Games Video Game Consoles & Games
Blue screen physical memory dump?
This is called the Blue Screen of Death or BSoD, this usually happen if u plug in or insert any new hardware. If u have recently added any new hardware, try it out, after plugging off the newly inserted hardware.
Jul 28, 2010 | Microsoft Windows XP Professional With...
Go to play the game and I get the blue screen of deaht AKA dumping physical memory
you set the physical memory in start-my computer-properties-setting(Start-up and Recovery) here you can set the default on is small ....64kb.
Dec 15, 2009 | The Adventure Company Agatha Christie: And...
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
This is not the problem of drivers it is the problem with the memory when one or more programmes try to occupy the same ram space at the same time if you want to get rid of this problem i suggest you to format your pc once and reload the os.
May 30, 2009 | Computers & Internet
Blue screen message, Dumping Physical memory.
It's really hard to say at this stage, and there's many more tests that you'll need to run in order to try and narrow down the cause of the problem(s). They could be anything from a potential virus infection causing conflicts, an incorrect video or audio driver being installed, to something corrupt within your windows OS, to potentially being something hardware related like your hard drive, or as you suspect, motherboard. You can try narrowing one of the major problems down, by backing up any personal data to CD/DVD or external hard drive, and then erasing the hard drive and reinstalling a fresh copy of windows and try reproducing the problem there. At this stage of the issue, it's all about trying to isolate where the fault is coming from, and this step will eliminate a lot of possibilities.
May 23, 2009 | Computers & Internet
Blue screen
hi daget200;
can you post the exact error message? its located at the top few lines so that we will know whats causing it. have you inserted a new hardware recently? when does the error occur? intermittent? does it happen when you are playing games or something? pls expound. thanks
Jun 07, 2008 | Computers & Internet
Disk Cleanup.
well..you sound as though there is too much on the disk..
Mar 29, 2008 | Dell Latitude CPI Notebook
Asrock K7VM4 Motherboard Logo
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
