Question about Olympus DS-2 Digital Voice Recorder
Recorder gives error on USB port
When I connect the recorder into the computer via the USB, I get a power surge error. Tried resetting several times as per instructions, but does not work. Other gadgets have no problem in the USB ports.
Please advise
  • Anonymous Jan 26, 2009
    I have the same problem. I get the error too, just starting up
    Eileen
This happened to me today. My first time to use a DS-2. The problem did not occur any more after I disconnected the cord from the recorder and reinserted it with the arrow facing down.
Posted on Jan 27, 2009
H1 won't connect via USB
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
Mar 25, 2017 | Zoom H4 Handy Recorder
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
My olympus vn-8100 flashed system error and stopped working
Ok, try this, works for me:
- Remove the batteries- Insert its again- Connect the recorder via usb to pc- Copy one by one each archive you need to recover, after copy delete them from the recorder- Copy SYSTEM, RECORDER AND MANUALS FOLDER to pc- Format from the pc the recorder (i use a mac - disk utility) yes it is, ERASE!- Copy again the folders: SYSTEM-RECORDER-MANUALS- Unplug the recorder, remove the batteries, insert again- Turn on the recorder, it will display a different error, format the recoder, it will restore and reset the systems files.- It works for me!-
Jan 10, 2012 | Olympus VN8100PC Voice Recorder
We bought my son an RCA mp3 player yesterday (TH1814-A). We inserted the battery and are trying to plug it into my desktop using the usb connector so that we can upload some music. however, when i plug...
There are different types of USB port. For instance my computer has two types. One with a blue connector and one with a black connector. It might be that your USB ports are not suitable for that device. You need to check the specifications of the USB ports on your computer and the specifications of the MP3 player. Continuing to use the device might cause damage to the computer.
Mar 19, 2017 | RCA Audio Players & Recorders
How do i get the recording onto my mac?
if you can connect via USB try that first. Your computer will see it as a storage device and give it a drive letter. you can open it up and selet all the audio files and move them to a folder (you assign) on your computer. If you don't have a way to hook up via USB you can reord the audio file into your computer by hooking up to the earphone jack on the recorder and the to the Pink audio in jack on your mac. open the software that you use for recording audio (garage band for example, or sound recorder). you will have to do this is "real" time however so if you have a lot of recordinng on the device it may take awhile to get the all transferred.
Mar 22, 2011 | RCA VR5220 Digital Voice Recorder
Power Surge on Hub Port
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Power surge
Connect the camera whilst it is switched off....then when you power on...it will ask if you want to connect via PC or bridge....if that still throws up power surge...you need to use a different cable as the power ballast on the cable is faulty.It is much easier to just use a card reader....cheap off eBay.
Nov 20, 2017 | Pentax Optio S40 Digital Camera
Power surge on hub port
I am having to send my wife's curve out for repair today as it seems that the very fine connections made to the circuit board from the power port have come away. This port seems to be very fragile, and poorly designed IMHO given that it has to be used so frequently.
Sep 03, 2008 | RIM BlackBerry Curve 8310 Smartphone
USB not being recognised by pc
what can happen is that the voltage supplied to the usb port is not enough to power the recorder to transfer data, assuming you have tried other usb ports, and tried leaving other connected peripherals out connected to a usb port, it is always better to use a mains powered usb hub when connecting things like mp3 players and digital recorders as some motherboards, especially low powered units struggle with some peripherals.
Aug 10, 2007 | Olympus WS-100 Digital Voice Recorder
Olympus DS-2 Digital Voice Recorder Logo
162 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
