Question about Denso 2000 Ford F150 Pickup 4.2L Remanufactured Alternator
Ford f150 4.2 v6 not charging put in new alt and battery
Not charing put in new alt and battery still zip
  • mw14660
    mw14660 Nov 01, 2012
    update........ upon reading a few post's here i went back at it and lo and behold i found a wre off from a pre fix hooked up and poof works fine
  • 127 Answers
You need to find the power regulator and change it.Usualy is inside the
alternator. check the wires.
Posted on Nov 01, 2012
Battery light comes while driving
Someone is missing something. Suggest alternator may be putting out voltage but not amperage or vice versa.
Apr 01, 2014 | Ford Cars & Trucks
Not charing
95 GC (this car the ENGINE PCM/ECU controls charge at all times.)
this year, the alternator is not a Standalone ALT> no internal reg.
my CHARGE lamp is on, is it? ah, Check battery above is not a verb its a lamp glowing. gotcha.
The system is called that a charging system
you connect any any voltmeter to the car battery
it must read 13.3 to 15v. running or the charge system is in failure mode.
top reasons,
1: bad batteries, yes, the Alternator reg, might just give up on a bad battery and just not attempt to charge it. so try that first. and the'
battery is the #1 failure on all cars...
corroded battery terminals or cable or alternator not grounded do to corrosion.
2: Fuse 6 or 8 blown in the PDC, both 60amp huge fuses.
3: bad wiring. bad connections to any of the alternators 5 connections.
5: the ASD relay can kill the ALT field current. as can the PCM.
6: bad ALT.
7: bad PCM.at pin C141.
i recommend (DIY) the FSM tests. or alldata.com .
there are test on car for each type failure.
id start with battery.
Jan 28, 2014 | 1995 Jeep Grand Cherokee
2000 ford focus dies when coming to a stop and battery light stays on. Brand new battery and alternator just put on
Battery light on ! alternator isn't charging . Test the alternator electrical circuits .Main cable on the back of the alt. should have B+ voltage .Pin # 3 at the connector on the alt. should have B + voltage - fuse F10 10amp under hood fuse box supply's B+ to pin #3 . Pin's 1 & 2 at the connector go to the PCM - engine computer . This is a computer controlled charging system .
Ford PCM controlled alternator testing
Feb 17, 2018 | 2000 Ford Focus
Put in new alternator,shows charging and battery holding charge but battery light stays on. You start car and light stays off for about 15 to 30 sec. than on.
The alt should charge at around fourteen volls , any ways, yogi need to put another battery. A weak alt will kill a good bat.and vise versa
Aug 30, 2011 | 2003 Ford Taurus
1986 ford f 350 6.9 diesel charging problem
Your alternator dosent work properly rechaange it again
Oct 23, 2017 | 1986 Ford F 350
.1991 Ford Aerostar 4.0 Lt engine, auto tran', electrical short ?
turn every thing on in park if voltage drops change alt
Mar 03, 2010 | 1991 Ford Aerostar Extended
1973 ford f250 trailer special. new alt. wont
That would be my first guess,they are not very exspensive,if this still does not help,run a large wire on the back of the alternator with the old one still connected,to the positive battery post.This will increase the voltage to the battery also.Put it on the large batt,connector on the alternator,and run it to the battery post+
Feb 24, 2010 | Ford F-250 Cars & Trucks
1995 ford contour has new battery and won't turn over at all
sounds like your alternator isn't charging the battery.take alternator to auto parts store to have it tested.
Mar 29, 2009 | 1995 Ford Contour
How to wire up 1975 Ford Courier Alternator w/external regulator?
just put a one wire alt. on it.or test each wire.
Mar 26, 2009 | Ford Cars & Trucks
Charging system
change your battery cables and check all wires on the alternator for loose connections, expecially the grounds.
Oct 02, 2008 | 2000 Ford Explorer
Denso 2000 Ford F150 Pickup 4.2L Remanufactured Alternator Logo
134 people viewed this question
Top Denso Electrical Supplies Experts
Lawrence Oravetz
wadingriver
wadingriver
pontelemon
pontelemon
Are you a Denso Electrical Supply Expert? Answer questions, earn points and help others
