Removing shock absorbers
Bosch WFL2450 (Maxx). I have removed the front panel and the bolt from the bottom of the shock absorber to the chassis. How do I remove the shock absorber from the drum. I cannot see a bolt it looks as if it is some sort of plastic pin. How do I remove it.
SOURCE: cant remove shock absorber "bolt/pin" frigidaire frontload washer
one end of thosepins has a tab on it, mash the tab with pliers while pullingon theother haundi24
Posted on Oct 13, 2009
Testimonial: "You knew exactly what i was talking about even though my question was a bit vague and confusing. I appreciate it a lot"
heatman101
  • 43501 Answers
SOURCE: removing frigidaire front load washer shock
The pins just push out...they are hard to get too and push hard...a screw driver and a hammer are what I used...
Get them started and then a pump pliers on the other end and you can pull them the rest of the way out...
Washer Problems Washer noise when spinning
heatman101
Posted on Sep 23, 2010
marka19
  • 1430 Answers
SOURCE: Kenmore front load washer broken
You need to squeeze the pointed tip and push the pin thru. Here is a link that should help http://appliancehelponline.com/frontloadstrutvideo.html
Posted on Oct 04, 2010
michiganfan9
  • 179 Answers
SOURCE: I need to replace the
There is a clip that needs pushed down. The easiest way is to put a socket on the pin over the clip. Then just pull the pin out. Sometimes the pins can be a pain to get out. I have taken a hammer and tapped the pin til it gets to the clip. Then push the clip down and tap the pin out.
Posted on Jul 15, 2011
rickyrt441
  • 4399 Answers
SOURCE: On a Whirlpool frontload washer-Model#GHW9150PW1--how
Thanks for choosing FixYa and welcome Matzie. The shocks can be removed by lifting the plastic locking tabs, grabbing hold of the upper portion of the shock and twisting CCW very hard 1/4 turn. Then, you can slide the shocks back together and reinstall them the opposite way. In some cases the shock can be very tight and difficult to remove. In cases such as this, try using a pair of channel locks to remove them or an equivalent. You can add WD-40 or some other kind of anti-lock lube but be sure not to soak it. If you do, the shock will be hard to grip. Grab the shock near the top where it meets the outer tub. Don't squeeze the tool to hard on the shock or you will damage it. Just hold the shock tight enough so that you can use a pair of pliers as a handle to turn it.
Posted on Jul 28, 2011
Torque setting 1999 300 ktm head &side cover
Thank you for contacting FixYa with your inquiry. I have been going over some of the inquiries that have been archieved and trying to provide solutions for those that didn't get answered. Hope this information helps.
KTM Torque settings
  1. Collar screw, front wheel spindle Front axle nut 40Nm 30ft lbs
  2. Brake Caliper front Brake Caliper front Loctite 243 2 19ft lbs
  3. Brake Disk, front Brake disk front Loctite 243 1 11ft lbs
  4. Brake Disk, rear Brake disk rear Loctite 243 1 11ft lbs
  5. Clamping screws, upper fork bridge Top triple clamp 20Nm 15ft lbs
  6. Clamping screws, lower fork bridge Bottom triple clamp 15Nm 11ft lbs
  7. Clamping screws, fork stubs Front axle pinch bolts 10Nm 7ft lbs
  8. Collar nut, rear wheel spindle Rear axle nut 80Nm 59ft lbs
  9. Hex nut swingarm bolt Swingarm nut 100Nm 74ft lbs
  10. Hex collar screw handlebar clamp Upper handlebar clamps 20Nm 15ft lbs
  11. Allen head screw handlebar support Lower handlebar clamps Loctite 243 4 30ft lbs
  12. Shock absorber top Shock absorber top bolt 60Nm 44ft lbs
  13. Shock absorber bottom Shock absorber bottom bolt 60Nm 44ft lbs
  14. Sprocket screws Rear sprocket bolts Loctite 243 3 25ft lbs
  15. Ball joint for push rod Rear brake pedal pivot Loctite 243 1 7ft lbs
  16. Engine mounting bolts Engine mounting bolts 45Nm 33ft lbs
  17. Engine brace Engine brace 33Nm 24ft lbs
  18. Screw adjusting ring spring preload Shock preload collar bolt 8Nm 6ft lbs
  19. Spoke nipple Spokes 5Nm 4ft lbs
  20. Other Screws on chassis M6 10Nm 7ft lbs
  21. M8 25Nm 19ft lbs
  22. M10 45Nm 33ft lbs
  23. Other collar nuts on chassis M6 15Nm 11ft lbs
  24. M8 30Nm 22ft lbs
  25. M10 50Nm 37ft lbs
  26. Front Sprocket 44ft lbs
Oct 29, 2011 | Motorcycles
Torque setting for centre nut for clutch housing
over some of the older help requests that have been archieved and
KTM Torque settings
KTM EXC Head Torque Specifications
Thanks for contacting FixYa. I was reviewing some of the older un-answered questions trying to ensure your issue has been resolved.
KTM Torque settings
  13. Shock absorber bottom Shock absorber botton bolt 60Nm 44ft lbs
  23. Other collar nutes on chassis M6 15Nm 11ft lbs
TF
Aug 26, 2011 | 2000 KTM EXC 300
Torque settigs on cylinder and head for a 2002 ktm 65
KTM Torque settings
May 15, 2011 | KTM 300 EXC Motorcycles
CYL HEAD BOLT TORQUE SPEC AND CAM HOLDER BOLT SPECS.
KTM Torque settings
TF
Apr 28, 2011 | 2008 KTM 450 SX-F
What are the torque settings?
KTM Torque settings
TF
Mar 11, 2011 | KTM 530 EXC-R Motorcycles
What is the torque for the head bols for a 2002 ktm 250 exc
KTM Torque settings
TF
Nov 07, 2010 | KTM EXC 300 Motorcycles
Head torque specs.on 1991 KTM540 2-stroke
KTM Torque settings
TF
Sep 03, 2010 | KTM MXC 520 Racing Motorcycles
Need a repair manual for my ktm 400sxc motorcycle
Try these:
KTM Torque settings
TF
Apr 13, 2010 | KTM SX 400 Racing Motorcycles
What is te torque specs for the camshaft retaining bolts
KTM Torque settings
\TF
Oct 28, 2009 | 2008 KTM 450 SX-F
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
