Question about Intel Core 2 Duo T7200 / 2 GHz processor ( mobile ) (S6161970) PC Notebook
I have 2 latops one is Levono T60 and one is HP NC6320 incidently they are bot h with Intel core 2 duo T7200 2Ghz and both went bad te T60 is cold dead ; it just quit with prio irratic flicking and n
My two laptop going down ; they are both wit Intel duo 2 core 2GHZ with processor T7200 - Do U know any quick fix or any common problems with this processor to show me how to fix them - I'm been blocking me to the outside of my world... Thanks in advance for your kindness . regards.
  • Roy young Oct 31, 2012
    Hi ,I need to know more about what yourr trying to do , please explain        Roy
SOURCE: motherboards for intel core 2 duo processor
just go to (Intel.com) for more info. on Intel core 2 duo processor
Posted on Dec 03, 2008
marketex
  • 371 Answers
SOURCE: can some one please let me know the name of the
The chips to which you refer are incompatible with respect to the socket used for each as well as the fact that Core duo and Pentium 4 1.5 GHz chips are from separate generations, the latter having been obsolescent since 2003. Therefore, there is no single motherboard that supports both, and the Pentium 4, Socket 478 boards can be obtained from various aftermarket sources.
Here is an example of the kind of board you need for your Pentium 4.
$11 to $290 from 21 sellers
ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc 3 reviews
ATA-100, Serial ATA-150, 0 MB / 4 GB (max), DDR SDRAM, Intel 865G, 4 x USB
Prepare for the future with the Intel Desktop Board D865GBF, a platform that is truly a generation ahead. This ATX board features next-generation processor, dual-channel DDR400 memory support, integrated Intel Extreme Graphics 2, an AGP 8X slot, 8 USB 2.0 ports, integrated 6-channel audio and next-generation storage device support.
FEATURES AND BENEFITS
Support for the Intel Pentium 4 processors featuring Hyper-Threading Technology and 800-MHz system bus in the mPGA478-pin package. Also supports the Intel Pentium 4 processors (1.60a, 1.80a, 2a, 2.20 GHz or higher) with 533-MHz or 400-MHz system bus in the mPGA478 package.
Intel 865G Chipset featuring Intel Extreme Graphics 2 using Dynamic Video Memory Technology (DVMT). Low-cost, high-performance graphics solution.
Dual-Channel DDR400 SDRAM support: Four DIMM sockets designed to support up to 4 GB of DDR400 SDRAM memory (also supports DDR333 and DDR266). Flexible support for either single- or dual-channel operation.
AGP 8X/4X graphics interface: Flexibility to upgrade via a high-end AGP graphics card.
SATA150 and Ultra ATA100 connectors: Flexible support of new-generation SATA150 (2 ports) and current generation ATA (2 channels) storage devices. « less
While the board for your Core Duo is widely available now
Posted on Mar 26, 2009
XOUSS
  • 48 Answers
SOURCE: difference betweeen intel celeron,core duo, mxx
Hello , Intel processors come in all shapes and sizes so I'll try to be brief by discussing only the ones that are current on the market. The market for intel processors are currently divided into 2 sides. One side if for single core processors while the other is for multi-cores. Single cores: Pentium 4, Pentium M, Celeron, Core Solo (Not very common) These cpus are single cores meaning that they only have one processor. They are relatively cheap compared to multicores. The difference between these are clock values, hyper threading, 64 bit support, and FSB. Pentium 4 and Celerons are cores found in desktops while the M is found in laptops. Single cores generally have low FSB but high clock speeds. Think of it as having a lot of water pressure but only a straw to dispense it. That's how fsb and clock values work. So single cores should provide you with a lot of raq power but they're not good at multi-tasking or jobs that requires it divide it's attention. Games like Crysis will be better with multi-cores because the pc has to generate so many different things at once while focusing on countless calculations and processes. the hyperthreading support does help the single core pentium 4s with multi-tasking but it's not as much as multicores. So if you're just looking for something with a lot of raw power. These are for you. Multi-Core Core Duo, Core 2 Duo, Core 2 Quad These are multi-core processors developed by intel. They are used in both laptops and desktops except for the quad. It's used in desktops only. The first 2 processors are dual cores while the last is quad cored. These processors have a high FSB rating and generally lower clock speed. So you have to be careful when looking at these. The high fsb means that the system does really really well with dividing and transferring it's processing power, but if you get a low clock speed then there's not enough power to begin with for the assignment. Example you may have a large hose but if you have low water pressure.. it's useless. That's why multi-cores are great for the modern pc user who multitasks way too much but if it's under 2.0ghz in clock speed. You should be worried about not having enough raw power to get you through intensive work. Multicores generally cost a lot more than single cores since they're relatively new technology. Btw the Core 2 Duo is faster than the Core Duo by about 7%. Meanwhile the quadcore is the ultimate in processor goodness but costs $400+. I hope these facts helped.
Posted on Jun 12, 2009
  • 157 Answers
SOURCE: i have intel dg35ec motherboard & intel p4 2.4
This is a laptop?? If those specs are correct then the laptop will run pinnacle studio 12 ultimate beautifully without any modifications.
Posted on Jun 16, 2009
bob_computer
  • 3153 Answers
SOURCE: Processor Error
Possibly a clock error or bios setting error. Thats an odd one !
Posted on Aug 18, 2009
Intel E6750 compatible?
Motherboard supports the following processor upgrades:
  • Intel Core 2 Quad (Y) Q9xxxx
  • Intel Core 2 Duo (W) E8xxx
  • Intel Core 2 Quad (K) up to Q6600
  • Core 2 Duo E6x00 (C) up to E6700
  • Core 2 Duo E4x00 (C) up to E4400
May 13, 2014 | HP Pavilion a6838f Desktop PC
Drivers vga download hpcompaqnc6400
Go to hp.com for drivers on an hp machine. They will be correct and up to date.
Jan 21, 2014 | HP Compaq nc6400 Notebook PC - Intel Core...
Power cord does not work
Does the power cord plug in to the charger seppertly or is it all in one unit, If it plugs in sepperately end your charger is still good just get a different cord for it,
Oct 25, 2012 | Lenovo Ibm Thinkpad T60 2007-59u Laptop...
I need to replace the Intel Core 2 Duo T7300 processor
you can check it up here for only $23.18
http://www.amazon.com/Intel-T7300-2-00Ghz-Fsb800Mhz-Fcpga6/dp/B00180IOLS
Aug 27, 2012 | HP Compaq 6910p Notebook
Biostar g31m7 te motherboard dvd download
DvD Players don't really have downloads. They are all standard and windows takes care of their drivers.
May 25, 2012 | Biostar G31M7 TE Motherboard Intel Core 2...
I am looking to buy a motherboad for hp pavilion part number 459565-001
Let's start off the week talking about Apple laptop motherboards! However, there is some good news for you mac user's but unfortunately some bad news about the notebook if your A1181 model contains the 820-1889-A logic board using the Intel Penryn setup.
The good news is Apple's new line of MacBook and MacBook Pro's come with the latest Penryn Intel Core 2 Duo processor, standard larger hard drives and most models already come with 2GB of memory standard out of the box. The bad news is that they do have a tendency to breakdown in the strangest ways, which in return requires you to repair or replace the laptop motherboard.
I receive a decent amount of e-mails about apple motherboards mostly about how the biggest issue seems to be that people are having a hard time figuring out where to even begin due to the lack of information provided by Apple and even on the internet.
The 820-1889-A PC main board do share a few very nice features - first and foremost it's made and used only for 2.1GHz to 2.5GHz (Penryn) CPU chipsets. All the logicboards have four wall connectors - Now they come standard with 667MHz memory support - You will find that this specific part number has one (8W) FireWire 400 port and two USB 2.0 ports (which come standard in the whole A1181 series).
13.3" White Using a 2.1GHz Intel Core 2 Duo.
The 13.3" and 15.4" White / Black with a Intel Core 2 Duo 2.4GHz.
Finally all 15.4" and 17" LCD models which have the 2.5GHz Intel Core 2 Duo processor.
Apr 08, 2010 | HP Pavilion dv6810US Notebook
Levono X301
Where as your mac is concren have you tried to reinstall the clean reinstall of MAc os? if not then try that once.
And you would get info about Levono X301 on
http://www.notebookreview.com/default.asp?newsID=4603
Dec 22, 2008 | Lenovo ThinkPad X301 Laptop Computer -...
Intel Core 2 Duo T7200 / 2 GHz processor ( mobile ) (S6161970) PC Notebook Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
