Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
What does err F1 mean? - Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
  • Official Brand Answer
  • 4,342 Answers
Hello - Typically error code F1 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Posted on Nov 02, 2012
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
Tip
What the F1 code means on your OVEN
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
on Aug 05, 2011 | Ovens
F1 ERR message on EOB
What is the make of your oven?
Dec 29, 2011 | Ovens
F1 code after installing oven, cut power to unit for 30 min. then F7 code displayed. What do they mean? This is a model SC302ZS Thank you for your help.
F1 means internal logic failure; control needs to be replaced
F7 means function key shorted (touch pad).
Hope that helps.
May 20, 2011 | Thermador SC302T Electric Double Oven
The oven beeps and has a error F1
Hello,F1 means Stuck touch pad.
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled,replace the oven control(also called clock or ERC),touch pad,or both.
Thanks
Jun 01, 2010 | GE JTP20 Electric Single Oven
THE OVEN DOESN'T WORK...F1 ERR
You need to replace the clock control
May 20, 2010 | Ovens
My stainless frigidaire professional series electric stove oven door is locked...i did not self clean it, but it is locked somehow...if i hold either the lock button, or the clear/off button for 15 seconds...
F1 is an EOC (electronic oven control) failure. The control is expensive. But before you go and buy this board, you need to find a diagram to see of this model oven lock is controlled by the EOC or by a micro switch. If you have a lock button on the board the you have to replace the EOC.
Mar 24, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven door locked itself. It will not let me use the keypad.
The F1 code means the ERC or the touchpad is bad.
F1 fault code generally implies that the electronic oven control has detected an internal malfunction. Most likely the cause is a shorted keypad which would require a new electronic control board. The electronic control board internal checksum may have been corrupted which also would require a new electronic control board. The control also may have sensed a potential runaway oven condition. The control may have a shorted relay, RTD sensor probe may have gone bad. The RTD is the oven temperature sensor probe which needs to be ohmed and the resistance should be 500 ohms or more at room temperature. If the resistance is less than 500 ohms, replace the oven sensor. Normally a technician is needed to make this check.
I recommend calling a service technician to diagnose and repair your oven.
Apr 11, 2009 | Kenmore Ovens
"F1" DISPLAYED AND BEEPING
hi there,
the F1 code usually means that you have a key stuck on the keypad. unplugging it from power won't make a difference for this one. is it a wall oven or a stove? can you supply the make & model please?
Oct 03, 2008 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
99 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
