Question about Sprint Sierra Wireless Overdrive Pro 3g 4g Mobile Hotspot
192.168.0.1 Changing setting
Changing the language on the 8L next book tablet
Click on the icon that looks like small square dots. from there look for Settings. Click on Settings > Then scroll to find Language and click here. Then find the English and set it to English.
In Spanish, Settings = Ajustes and English is Ingles
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Jul 30, 2016 | Tablets & eReaders
Why does my wifi disconnects when i turn off my tablet?
You probably have the setting for WiFi set up to where it shuts off while in sleep mode. You can probably fix it by going to your settings and changing the WiFi setting to always on. Not sure which setting its under but just select and check out each setting category until you see something that relates to changing wifi setting. I could be more detailed but would have to go there to be sure which exact setting.
Mar 15, 2015 | Android Tablet
My oven setting keeps changing
check the oven temp control thermostat and the oven temp probe with a meter
lastly the control board
Nov 09, 2014 | Whirlpool Ovens
Screen won't return to full size.
Have you tried to re-set the Aspect Ratio from either the remote control or going into the Menu setting & changing the picture size?
This is the settings for changing different size of screen formats eg 16:9
Aug 27, 2013 | LG 32LG30 32 in. LCD HDTV
Keep timing from changing and keep it set to where it is set?
sounds like you arnt tightening everything properly as when timing is set it shouldnt move
Aug 17, 2012 | 1999 Mercury Mystique
Problem with the Sony Playstation 3 (PS3) Console PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
Try changing your DNS settings on the PS3 or on the router
Changing the DNS on your router: Go to 192.168.1.1 Default password is: admin Static DNS1: 208.67.222.222 Static DNS2: 208.67.220.220
Those DNS setting are from OpenDNS
After doing this, reconnect your PS3 to the router and set it to Automatically adjust the settings. Once you have reconnected, check if you are still having the DNS problem.
If you are still experiencing the problem, try changing the DNS directly from the PS3 Go to Internet Connection Settings and set everything to Auto except DNS When asked if you should set the DNS automatically, choose "Manual" Input the same DNS settings: Static DNS1: 208.67.222.222 Static DNS2: 208.67.220.220
Apr 09, 2011 | Sony Playstation 3 (PS3) Console
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Replacing battery lead to loss of keygaurd security code set by my own after changing it from the default factory settings
replacing battery lead to loss of keygaurd security code set by my own after changing it from the default factory settings
Dec 26, 2009 | Nokia 2610 Cellular Phone
Screen size changing back and forth on its own
Try going into the menu format setting (4.3 or 16.9 or auto) and change setting from auto to 16,9 and store setting.
SUPER8
Dec 01, 2008 | RCA HD52W59 HDTV Projection Television
Sprint Sierra Wireless Overdrive Pro 3g 4g Mobile Hotspot Logo
158 people viewed this question
Top Sprint Computers & Internet Experts
matt
matt
Are you a Sprint Computer and Internet Expert? Answer questions, earn points and help others
