Question about Kenmore Magic Blue 24195 Bagged Canister Vacuum
Kenmore blue magic lid is stuck and the lid release latch will not open canister
The lid release latch works on my kenmore blue magic but the filter cover still will not open. It's as if it's jammed/stuck closed and I'm afraid to force it open
4 Suggested Answers
  • 55 Answers
SOURCE: lid will not snap shut over vac bag on kenmore magic clue
What kind of vacuum do you have?
Posted on Dec 01, 2008
SOURCE: I've changed the bag, but I can't the lid to close
don't be afraid the vacuum is not gonna die
Posted on Jul 24, 2010
  • 2926 Answers
SOURCE: I have a progressive 360
There should be tabs that need to be pressed in, and will allow the filter cover to be removed to access the filter. On some models, the tabs are accessed from the bottom by tilting the unit on its side, or by simply pressing them in from the top, then pull the filter cover up.
Posted on Jan 21, 2011
Stuck closed, how to open?
press release on top cover , I had someone use mine 1ce and they pressed "seal" with no bag in machine it did exactly that it stuck closed, tight too !! one touch of release button on top cover and it popped open
Jan 15, 2016 | FoodSaver V3250 Vacuum Sealer Kit
Lid of filter section stucked in Hoover Vaccum Cleaner Model UH70115
Hi Bharat! In the front of the dirt cup near the top there is a red Hoover emblem that is also a latch to open the dirt cup lid. Pull on dirt cup latch to open lid. Hope this helps!
Sep 17, 2014 | Hoover UH70015 Bagless Upright Cyclonic...
How do I open lid of filter section of Hoover vacuum cleaner model UH70115
Page 9 of your Owner's Manual; Press dirt cup release button (A) & pivot cup out.
Sep 17, 2014 | Vacuums
Shop Vac lid will not securely latch. 1
Are you sure that the filter is pushed all the way to the bottom of the container? Just take it out and put it back and make sure the filter retainer is gently turned all the way.
May 19, 2013 | Shop Vac Vacuums
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
I just purchased a floormate. I can't seem to get it to spray cleaning solution.
Turn the cleaner off and then on again to determine whether the cause of no suction resulted from the activation of the automatic shut-off. There are two reasons a tank will automatically shut off. The first is if the recovery tank is full. Located on the lower front panel of the unit, the recovery tank can be easily emptied and replaced into position. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
Turn the unit on again and check the suctioning action. The second reason automatic shut-off could take place is if the handle was raised to an upright position while the motor was running. Should this occur, simply turn the unit off, wait a moment for the shut-off to reset, and turn it on again to continue cleaning.
  • 2 Make sure the filter and filter lid are properly positioned in the recovery tank lid. The cause of the problem could be that the filter or the filter lid were missing or were not in the proper position.
  • 3 Check that both recovery tank and/or solution tanks are locked in place and are positioned properly. The recovery tank is located on the lower front panel of the Floormate, and the solution tank is located in the front top panel of the unit. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
  • 4 Observe whether filter is dirty. If the filter is dirty, clean the filter by turning the cleaner off and disconnecting it from the electrical unit. Take out the recovery tank and lid. Remove loose debris from the filter by wiping clean with a brush or tapping the filter over a garbage can. After this is completed, the filter may be rinsed clean for additional cleaning and then air dried before returning the filter to the unit.
  • 5 Check that the nozzle is in the proper position and locked. Locate the nozzle underneath the suctioning base of the unit. Make sure the latches are out and line up the middle section of the nozzle with the opening of the cleaner. Hold the nozzle in place while simultaneously sliding the latches inward to lock in
  • Mar 07, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
    Kenmore Magic Blue 24195 Bagged Canister Vacuum Logo
    88 people viewed this question
    Top Kenmore Vacuums Experts
    Chris Nomland
    Chris Nomland
    Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
