Question about KitchenAid KEBC247 Electric Double Oven
Kitchen aid oven kebc self cleaned and now won't heat kebc107kwh05
Powerman
  • 68 Answers
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
  • 1314 Answers
SOURCE: kitchen aid wall oven kebs177dssp
call whirlpool tecnical assitance see if they have a kit for it tech knows parts people dont most of time they do beleive or not they want it to work right been working for the factories for years and they doo care
Posted on Dec 29, 2007
  • 833 Answers
SOURCE: self cleaning
Sometimes, according to what I've seen.  My theory is that the elements are probably covered in grime and this causes the damage.  As far as the control...I don't think that makes sense.
Never use cleaner on the elements..also causes damage.
A typical duty cycle for cleaning is 2- 2.5 hours.  Longer and you could burn them up, too.
Posted on Nov 28, 2008
  • 3 Answers
SOURCE: I hit the self clean button on my Kitchen aid oven and now the door is locked and the oven lights are off
I have heard that with this model, the self clean will ruin the electircal components. It sounds like you may need to have someone test it out to find what is ruined. If I were to guess I would say its the controller board. Mine was on backorder for 2 months.
There is a person in this link that has the same issue:
http://www.consumeraffairs.com/homeowners/kit_stoves.html
Posted on May 14, 2009
localwonder
  • 6784 Answers
SOURCE: kebs208d THE DOOR WILL NOT UNLOCK
HI, this is a major control fault. you will need to replace the Oven control asap if possible. It has failed.
Possible causes--
*Power surge
*Failed logic(IC)
*Oven Temp Sensor failuer that has resulted in extreme temps that has overheated the board.
Posted on Jun 07, 2009
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    It is a free standing kitchen aid oven. I put it on quick self clean and it said it would end at 2:00. The panel went blank at 1:20 and it is past 2:00 and it is still locked. I checked the circuit br
    Unfortunately KitchenAid ovens notoriously blow a thermal fuse when you use the self cleaning cycle, and if you're lucky that's all that happened. Hopefully your oven is still under warranty. If so, call KitchenAid customer service and they will repair it for free.
    If you're handy you can check/replace the thermal fuse yourself (requires pulling out the oven and taking off the back panel, finding and replacing the fuse- be sure to turn off power and gas first).
    Nov 13, 2012 | Ovens
    Frigidaire oven won't heat past 355
    Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
    Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
    Owner's manual re self clean feature Kithcen aid Superba27 self clean double oven purchased 1988 Cannot get it to turn on and heat. The Lock light does not go on and no heat is generated.
    Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
    Jan 17, 2011 | KitchenAid Ovens
    Oven not heating
    Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
    Also check out this tip...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Apr 13, 2010 | KitchenAid KEBC277 Electric Double Oven
    I used the cleaning feature on my kitchen aid architect series oven KEBK101 - now when you turn the oven on it does not heat up - what part do I need to replace - Kitchenaid will not address
    Yup Thermofuse stops the elements from heating after the self-cleaning cycle. You have to take out the oven, TURN OFF THE POWER at your circuit breaker, remove all the screws on the oven back panel, you'll see the thermofuse near the center (there are two 1/4" spade connectors (one leads from one leg of the power junction box). Two screws to remove it.
    Oct 27, 2009 | KitchenAid KEBC107 Electric Single Oven
    Kitchen aid wall oven kebs177dssp
    Dec 22, 2007 | KitchenAid Architect Series KEBC107KSS...
    Self Clean does not work
    Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
    heatman101
    " Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
    Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
    KitchenAid KEBC247 Electric Double Oven Logo
    44 people viewed this question
    Top KitchenAid Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
