Question about HP Photosmart C4580 All-in-One InkJet Printer
I can't get the ink to fit into the slots.
I just got the hp c4580 printer/scanner and i have been trying for over twenty minutes to fit the ink into the slots and  read the directions over and over. They only say to push the ink in. how hard do i need to press it? which way do i need to press the ink?
  • 3 more comments
  • Anonymous Jan 12, 2009
    Did you get your printer from the Apple Store? Same issues...
  • Anonymous Feb 13, 2009
    me 2 what should i do?
  • flynnl Apr 16, 2009
    The colr cratridge snaps in just fine the black one flops out exchanged the printer for a new one and the same problem doe snayone know what needs to be done to get the balck one to fit ?
  • Anonymous May 01, 2009
    Yep... got mine from the Apple store too. I was just trying to replace the black ink cartridge. Not only can I not get it clicked into the slot, but it won't even take the color cartridge it came with. Very frustrating.
    Same thing. Got it at the Apple store
  • 52 Answers
If you have purchased the printer with the ink cartridge then insert the ink cartridges with the GOLD(contacts) facing towards the printer. If you are replacing the ink cartridges, then you must make sure that cartridge numbers are the same as the empty ones.
GOOD LUCK
Posted on Jan 03, 2009
HP Photosmart C4580 Print cartridge(s) missing or not detected
This error message usually happen if the cartridge is not properly seated or the copper-colored electrical contacts have problem. Check this website for proper cleaning and installing ink cartridge.
If the problem is resolve try replacing the ink cartridges.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01442936&lc=en&dlc=en&cc=us&lang=en&product=3418707#N68
TNX
Apr 23, 2011 | HP Photosmart C4580 All-in-One InkJet...
How do i check ink levels on hp c4580
Go to Control Panel, select view Devices and Printer, right click the selected printer, select Printer Properties, left click Preferences, and check ink levels from cartridges.
Jan 03, 2011 | HP Photosmart C4580 All-in-One InkJet...
I HAVE AN HP PHOTOSMART C4580 ALL IN ONE PRINTER SCANNER COPIER THAT KEEPS GIVING ME A PAPER JAM. I WAS TOLD I NEED TO RESET THE HARDWARE OF THE PRINTER
It's one or two things. First make sure there is nothing stuck in the printer. Such as, a paper clip, coins, or even a staple. Make sure you take all the ink cartridges out of the printer. Shake the printer and see if anything falls out. Good luck!
Dec 08, 2010 | HP Photosmart C4580 All-in-One InkJet...
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    My hp printer c4580 won't accept refilled ink cartridges how do i do this rodney
    > won't accept
    Error-messages? What happens? What does not happen?
    Did you refill the ink-cartridges yourself, or did you take it to a company that does the refilling?
    Dec 11, 2009 | HP Photosmart C4580 All-in-One InkJet...
    I am missing a ink cartridge and my hp photosmart C4580 wont let me use my scanner
    This is because printer and scanner are connected together.The printer need both cartridges installed to initialized and then initialized the scanner.Just put the missing cartridge and problem will solve.
    Oct 29, 2009 | HP Photosmart C4580 All-in-One InkJet...
    HP Photosmart C4580 All-in-One InkJet Printer Logo
    126 people viewed this question
    Seeker5211
    Seeker5211
