Question about JVC AV-36320 36" TV
Jvc model av36230
I have a jvc 36 inch tv that when you turn it on the picture and sound is ok except the top of the picture tube there is about an inch where it is dark and under that there is 3 to 4 fine lines going across the screen please any help greatly appreciated it appears to be in the vertical section????
  • 45 Answers
You know its in vertical section, try to look for a capacitor and changed it, this is more of a capacitor problem.
Posted on May 16, 2007
Sound ok but no picture
see the b. diagram and test the power supply ;transistor, fuse, filter, switch, c.breaker rectifier,IC regulator voltage.
measure the horizontal output =125vdc
all other circuit:12vdc
color:12vdc
Oct 17, 2012 | JVC Televison & Video
TV power red light is blinking and no sound or picture
Model number if not the one listed here will be on label on rear of set along with month and year the set was made--
How skilled are you with working on (I presume it is a older direct view with a picture tube) sets?
A lot of the older JVC sets had a common issue---there is a single filter cap (it will look ok) that fails----Tell me model and If you are able I will try to direct you to it.
May 18, 2012 | JVC AV-27230 27" TV
I have no picture on my JVC AV-27730 tv. Where is the picture tube and can i replace it myself?
Hello
Picture tubes are available at electronic spare part shops. You have to give them the number and type of the picture tube, to which your JVC TV has. Picture tube, along with its Yoke fittings are integrated, and you can replace it by yoursef at home. Be very carfull in handling the picture tube, as they are highly vacumed, and will explde by hard hits. There will be four seating screws on the four corners of the picture tube, and these slots will clearly alaign if the picture tube selected is orginal number. Diamentions of these holes will be different to spherical and flat picture tubes. So you must first aware of the type of picture tube, which the TV has fitted earlier. OK.
Mar 06, 2011 | JVC AV-27730 27" TV
Picture turns completly purple after being turned on for about 10 seconds. Can see faint picture"behind" purple. sound works fine.
Sorry to tell you this, but that's one symptom of a bad picture tube. After it's warmed up a little, one of the elements in the neck touches something it shouldn't and you see the result. There's no repair except a new tube, and that's completely uneconomical. It would be less expensive to replace the set.
Mar 23, 2010 | JVC AV-27S33 27" TV
GE television
My GE 32 inch won't come on, when you turn it on you can hear click two to three times then it comes off.
I have another 32 inch GE TV that has no picture except white/gray light on the picture tube, but there is sound
Oct 20, 2008 | GE (-25001RE2) Audio Conference
Jvc tv
Before confirm the picture faulty go and the select the blueback option ON in menu option. Disconnect the cable signal and check the tv displays bluescreen. If it is there picture tube will ok, fault in C board. May be dry contact in blue output section the picture tube conducts heavily the respective color.
Sep 14, 2007 | JVC AV32F577 32" TV
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Jan 29, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Tv on with sound but no picture
my jvc tv has sound but no picture. Sometimes when I turn it off for a few minutes it has picture then it goes black
Aug 07, 2006 | JVC AV-27230 27" TV
JVC AV-36320 36" TV Logo
136 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
