Question about Pioneer VSX-816-K/S Receiver
Pioneer VSX-816 cannot display System Setup menu
Hi
Had this problem before, it was a quick fix, can't remember...
Right now, I am not able to view the System Setup menu on the TV. Tried various different hook ups, video cords, etc.
As this is the very beginning to setting up speakers, speaker levels, etc. it is very frutstrating.
Any help would be much appreciated.
Thanks
Sandi
  • Jeff Arv Apr 06, 2009
    I am having the exact same problem with my Pioneer 1018. When I try to select system setup, the receiver shows "Cannot Select".
    I've tried every cable and input option I can think of.
    Did you ever get your problem fixed? If so, what did you do?
  • 4234 Answers
SOURCE: Pioneer VSX-816
The blinking usually means that the unit is in "protect" mode. Check the output transistors for a shorted condition and replace.
Dan
Posted on Mar 18, 2008
ginko
  • 19396 Answers
SOURCE: connecting Pioneer VSX-816 Reciever to SONY DVR player
Check
Connect a DVD Recorder to a TV. Connecting a DVD Recorder to a TV
Posted on Jun 08, 2008
  • 4 Answers
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Posted on Aug 12, 2009
  • 39 Answers
SOURCE: pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Posted on Sep 13, 2009
SOURCE: Overheating receiver
I opened my receiver up and found the fan not working. So I took the front of the unit off so that I could access the fan. It looked brand new so I don't think it ever worked. I checked the fan connection with a volt meter and found 12 v only the fan still would not run. I took the red wire coming from the fan and put it to ground. Cut the yellow wire off the fan. and the black wire to the middle of the connector on board. there the fan worked. now I have a working fan. maybe this could be your fix just don't lose the screws and remember how this comes apart. I know the fan works not so sure it fixes problem but at least the fan is working so thats a start. At least it won't overheat. hope this helps
Posted on Nov 22, 2009
Trying to fix my Pioneer VSX-816 and when I turn it on it says overload and shuts off. Nothing is plugged into it, and I suspect the STK412-230C chip or STK413-230C chip is bad. Is there any method to...
Unfortuneately no! Regardless, you are better off changing both because of the stress they were both put under. When you change one and not the other it is a matter of time before it goes completely taking the new one out along with it. It is important to check speaker wires for shorts, and speakers to be on the safe side.
Mar 21, 2012 | Pioneer VSX-816-K/S Receiver
Pioneer VSX-1018AH-K 7
Check if Zone 2 is 'On' if it is set it to 'Off' using the front panel button. Hitting the 'Recieiver' and 'Setup' buttons is the correct way to set the system up.
Sep 29, 2008 | Pioneer VSX-1018AH-K Receiver
NEW WITH LCD TV
This pioneer does not support HDMI, so for the best resolution you have to use video the component inputs and output, those are marked as Y (green), Pr (red) and Pb (Blue) and remember, this signals are only for video so you need to hook up the audio too.
Nov 30, 2007 | Pioneer VSX-816-K/S Receiver
Stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Oct 07, 2007 | Pioneer VSX-816-K/S Receiver
Vsx-815 steady blinking blue light
Hold "Enter" and "Advnc. Surrnd" buttons on receiver at the same time.
Dec 29, 2006 | Pioneer VSX-815-K Receiver
Pioneer VSX-816-K/S Receiver Logo
79 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
