Question about Pioneer PureVision PDP-50MXE1V-BNC 50 in. Plasma Television
Connecting Pioneer PDP-50MXE1 using DVI-D
I have the Pioneer PDP-MXE1 and am trying to connect it to my Sony STR DG710 AV receiver i have the sound side sorted but i cant get no picture when i connect the two up using the DVI-D, i have a HDMI to DVI-D adapter in the DVI-D slot, but the picture remains black, i do not have the RGB video card for the TV, is there any way i can connect this with the inputs i have or is the only way to get the RGB card for the TV?
Many thanks
Anthony
Sony STR-DG710 center speaker makes no sound. Connections are good.
Sometimes these units have the ability to switch the speaker off and on. Look up the speaker settings in the manual.
As each channel in the unit will be separately driven the power amp for the center channel could have failed, but I think it's unlikely unless you have had problems with the sound on it before, or connected it wrongly causing a fault.
Dec 16, 2016 | Sony STR-DG710 Receiver
Conia plasma 42inch connecting to macbook pro - ??
Hi, i also have a conia plasma (and sony 510 amp). Which video connection are you using? DVI-VGA? DVI-component? Note that the tv probably defaults to using YPBR rather than VGA so you may need to play with settings in the menu ...
Aug 12, 2008 | Sony STR-DG510 Receiver
I am using an HDMI cable on my STR-DG710 and get no sound
A lot of devices like PS3, HD DVD Players, Cable boxes, etc., require you to define on the setup menu if sound will be coming out of the HDMI cable or not. Most of these devices can be set to HDMI Auto, but not all of them do.
I currently have both my Blu-ray and HD DVD player outputting both video and sound through my HDMI into my STR-DG710. Both devices are setup to output sound through the HDMI.
But like the other person on here posted, it you have a DVI to HDMI cable, you won't be getting sound. The only device that will output sound from a DVI to HDMI are select computer graphics adapters like the GeForce 9800 GT series video cards, and even not all of those will have this feature.
Hope this helps.
Jun 23, 2008 | Sony STR-DG510 DTV Receiver
Sony STR-DE545 5.1 not working
Are you connecting from your DVD player to receiver using an optical cable or simple AV cable?
Nov 06, 2007 | Sony STR-DE545 Receiver
Pioneer PureVision PDP-50MXE1V-BNC 50 in. Plasma Television Logo
188 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
