Question about Electrical Supplies
I have a Coleman pro gen 5000 need wheel kit - Electrical Supplies
SOURCE: Need to know about this
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Posted on Mar 16, 2009
  • 251 Answers
SOURCE: Coleman Powermate Pro-Gen 5000, not been use in
remove bowl from the carb . clean it out ,and check for free fuel flow
Posted on Oct 20, 2009
ROMOAS
  • 97 Answers
SOURCE: I have a Coleman Powermate
when the engine sets for a long time the gas can seep bast in to the cylinder and their will be some gas you will need to change the oil and take the spark plug out and air i suggest you squirt a small amount of oil in the cylinder gas in the cylinder can wash out the lube to the rings and cause undo wear and start smoking turn the engine by hand slowly to allow lubing of the rings the gas seepage is most likely caused by a float that's not set correctly you may need to rebuild the carb with a kit around 20 bucks ans easy to do at least the clean it well to remove schlack that gas leaves behind when it dissipates and can cause issues.
replace with fresh gas and run the engine and it will smoke for a couple mins do to the oil in the cylinder remove the spark pug after running a couple mins and clean or replace the engine should be fine following the steps above. hope this helps
Posted on Aug 31, 2010
  • 7 Answers
SOURCE: have a coleman powermate 5000 gen. starts fine
Sounds like you may have a stuck float. It is inside a cup that hangs down under the carburator, there should be a nut and a serrated screw adjustment value. Put a empty coffee can under it to catch the gas and remove the nut the cup will fall off into your hand, you will see the float make sure it moves up and down on it's own weight. Sometimes they get old and stick it is held in place by a small pin (don't loose the pin) unscrew the adjustment pin counting how many turns it tales to remove, clean every thing with carberator cleaner, you may have to buy a new gasket for the top of the cup, they are very thin and break easily. Reseat the gasket in the groove it came out of, put the cup back in place and put the nut back on just an-off to make it good and snug, screw the value pin back in place counting the turns so it sits were it was before. Make sure the gas value is open and try to start the engine, at first it will fill the cup with gas then it should start up. If not you may have to disasseble the caberator and clean all the tine little ports, I have one that was so bad I just had to replace the caberator.
Posted on Apr 18, 2011
  • 1383 Answers
SOURCE: i have a problem with
To find the correct part on line, first determine the engine model number and code stamped or labeled on the engine fan cover. For example will be Briggs, or Honda etc. Once you determine the Engine brand and model number, you can go to a web address like Jacks small engine, or even ebay or a replacement part or carb kit. May be easier to take the engine information to a mower repair shop in your area for a replacement. The engine on your generator is similar to one used on lawn equipment. Good luck
Posted on Aug 02, 2011
I have a Coleman Pro-Gen 5000 with a Briggs and Stratton motor in it, I was wondering what kind of oil to use in it and what size sparkplugs I need
30W OIL, take old plug to store customer service will match. Parts: http://www.ereplacementparts.com/powermate-generator-parts-c-117046_130613.html?gclid=COe1kb_yi80CFZGJaQodXvYMXg Info: look on valve cover "DOHC" marked. On the side is the model number for the engine. Search on that model number for engine parts.
Jun 02, 2016 | Coleman Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Where can I buy a wheel kit for a Coleman Powermate 5000 Genterator ?
Do an online search. I bought mine that way years ago.
No, I have no idea where.
Aug 26, 2014 | Coleman Powermate Powermate 5000W...
I have a problem with the carburator at my coleman powermate pro gen 5000, where i buy this carburator on line. thanks
Aug 02, 2011 | Coleman Powermate Powermate 5000W...
I have a Coleman Powermate PRO-GEN 5000 (6250). It has been sitting for a year and the gas value was not shut off (oversite). When checking the oil, it smells like there is gas in the oil-is this possible?
Aug 03, 2010 | Coleman Powermate Premium Plus 6250W...
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
140 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
