TV picture won't open.
32" Sylvania color TV about 4 years old. Sound is fine but the picture will not open. There is a horizontal line of color, movement and light about 1/4 inch wide across the width of the picture tube but it will not open the rest of the way. Have tried turning it on and off and get the same results every time for several weeks.
  • 40 Answers
The vertical sync circuit has gone'll have to have it repaired if you want to keep it
Posted on Jan 03, 2009
Need help with horizontal hold on 1971 Sylvania TV
it is better to use audio video input of your tv .syncronisation problem in the Rf stage cannot be solved easily.
May 24, 2014 | Televison & Video
Sylvania SRT2232S 32" was working
The problem is in the vertical deflection circuits which is responsible for giving a full picture. Since the set is 8 years old the money would be better spent on a new tv since more frequent break downs in other parts of the set would be more likely due to age.
Sep 15, 2011 | Sylvania SRT2232S 32" TV
Vertical line picture
problem is caused by the loss of horizontal deflection signal. It is quite surprising that the entire unit is still working, since usually, a loss of H-Out will disable the entire set. Problem can be as simple as loose solder connection to a more complicated defective horizontal circuit. I would suggest havint it checked by a professional TV tech.
Jul 16, 2008 | Proscan PS36500 36" TV
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
Jul 13, 2008 | Toshiba 32A40 32" TV
Horizontal lines on top fourth of picture
the guy who sold it to you has the same white lines on his forehead.emagine that. wallmart is real cheap.
Jan 04, 2008 | Sanyo DS32920 32" TV
Poor picture quality
You need to consider the following tips herein as follow:
1) Field collapse (horizontal white line on screen)
R710 dry joints. Same as C2146TN & C2546TN problem solved with thanks to Mike G & Barty. Power off/unplug. Get to circuit board underside with aerial socket up-R710 is near top and right of centre-cluster of 4 joints best resoldered
2) Picture is horizontally narrowed and deformed
Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
Please let me know any update
Nov 29, 2007 | Toshiba 27AF42 27" TV
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Sony KV-32S36 32" suddenly stopped working, no picture or sound
Check soldered in fuse R607 in power supply circuit =
If open, replace it and bad converter xistors ( 2SC4834)
Next, replace shorted horizontal output transistor w/ first Quality.
Solder any / all bad connects,esp.horiz drive to base of horiz.
o / p xistor. Soldering is critical or it will blow up again......
Oct 27, 2007 | Sony KV-32S36 32" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
