How to check voltages on asus IPILP-AR (Locktite) motherboard (micro ATX power supply)
  • 89 Answers
Go on google and look for a program called everest home edition this will give you diagnostics on your comp here is a link http://www.softpedia.com/get/System/System-Info/Everest-Home-Edition.shtml
good luck and tell me if you have more problems
Posted on Jan 06, 2009
-12volt not show
check your power supply first, then voltage regulator chip/transistor/caps
Dec 14, 2015 | ASUS P5KPL-VM - motherboard - micro ATX -...
What means sb pwr
'SB' stands for StandBy. When the motherboard is connected to the power supply but not turned on the SB voltages are supplied to different parts of the motherboard. In some motherboards you are able to charge devices like Phone without powering on the computer, that's because of the SB.
The SB in turn triggers other voltages used for the motherboard.
Oct 13, 2013 | ASUS M2N-VM DVI - Motherboard - micro ATX...
I have an Hp m260n. I just need to find out what type of case it has (ATX or uATX).
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00026876
Motherboard: ASUS P4SD Motherboard Specifications
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00022505&lc=en&cc=us&dlc=en#c00022505_doc
Board Form Factor: uATX
uATX stands for Micro-ATX,
http://en.wikipedia.org/wiki/MicroATX
http://en.wikipedia.org/wiki/Computer_form_factor
http://en.wikipedia.org/wiki/Computer_form_factor#Tabular_information
HOWEVER, the Power Supply is an ATX form factor,
http://www.911forpcs.com/hp-media-center-power-supply.html
,of a sort.
Form Factor related directly to desktop computer Motherboards.
Now has 'evolved' to relate to the computer case, and Power Supply.
When referring to a Power Supply, and the ATX form factor; you are not only referring to the size, and shape of the Power Supply's case; but also the type of power cables used, and the technology used within.
Size and shape of an ATX power supply is approximately;
6 Inches Wide, 5.5 Inches Long, and 3.5 Inches in Height.
(152.39mm Wide, 139.69mm Long, and 88.89mm in Height)
Power cables included with Power Supply's nowadays, will include all the power cables you'll need, with probably some left over.
HOWEVER, looking at the 'ATX' form factor designated for your computer, to wit from the ad above, it does NOT fit the above size, and shape.
More like 6 Inches Wide, 4 Inches Long, and 3.5 Inches in Height.
Looks like they just crammed everything into one small box.
Remove motherboard, and all internal hardware, into a new computer case?
No prob!
Most Mid-Tower to Full Tower size computer cases, will have a Support Plate that accommodates a Micro-ATX form factor motherboard, OR an ATX form factor motherboard.
Just look at the Support Plate mounting holes.
Ones for a Micro-ATX (uATX) motherboard, will have uATX next to them, or MATX, or mATX.
Ones for an ATX motherboard, will have ATX next to them.
However check the computer case manufacturer info to be sure.
[ The motherboard mounts to a Support Plate.
The Support Plate can be an integral part of the metal frame, of the computer case; or a separate metal plate that attaches to the computer case metal frame ]
Not what you had in mind Joel? Post back in a Comment.
Regards,
joecoolvette
Feb 17, 2013 | HP Media Center PC M260n (DF200A#ABA) PC...
P8P67 EVO Won't Boot with power to board
This is almost always the power supply. How exactly did you "check the power supply"? You checked all 12 or so voltage outs under load?
If replacing the power supply doesn't work, replace the motherboard.
Dec 24, 2012 | ASUS P8P67 EVO LGA 1155 Intel P67 SATA...
My computer restarts by itself in a never ending loop
I have had this happen to my computer multiple times. Once it was because the system was overheating due to the CPU fan and case fan being dead, and the second time it was due to a short in the power supply. I would check either of those two things.
Nov 11, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Will a asus P4533-E motherboard handle a 550w atx power supply without ruining the board?
Yes, the power supply is set to send only the required voltage to the motherboard. The reason you want a large power supply is to handle all the other power hogs (video card, hdd, sound cards, fans, dvdroms, etc...)
Nov 05, 2009 | ASUS P4B533 Motherboard
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Computer won't boot up
Have you tried a higher rated ATX power supply? Preferably a 350w.
Apr 22, 2009 | ASUS SiS Chipset TUSI-M Motherboard
Power supply wont come on
I've check and that board uses an ATX power supply. that is your problem. slap in an ATX and you'll be good to go. Please be so kind as to rate this answer thanks and good luck.
Jan 28, 2009 | ASUS A8N-SLI Premium Motherboard
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
