Question about Honeywell Programmable Thermostat Heater
Hello, I have a Honeywell thermostat T8001C and al of a sudden started to reduce the temperature when set at heating. I set it at 75, it goes to 70. I even played with the HOLD button to keep the temperature at 75. Does not work. Then I took it down and when set back has no display. I toggled - as many say here - with the E-F switch and put it back on F still no display and no HEAT. If I turn to FAN ON I hear the fan kicking in, still with no display. So the unit gets power but does not turn on the heat and no display. Any help please? gtc1961@live.com
  • 579 Answers
SOURCE: honeywell round mercury thermostat - heat not coming on
If you tip the mercury switch so that it makes contact and the furnace doesn't start, it isn't the t-stat. Check the connections, then start checking the furnace.
In any case, ditch the mercury t-stat (recycle it properly) and get a new programmable one if at all posible. It will pay for itself many times over by turning your heat down in the middle of the night and back up by morning.
Posted on Feb 10, 2008
  • 3 Answers
SOURCE: wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Posted on Jan 05, 2009
SOURCE: Thermostat seems to be working, furnace does not always turn on
i need help rplce thrmostat with a digital braueburn my furnance wont turn on no flashing lights cant reset the burner though has power what do i do shoul i reset the circut breaker that was never tripped though
Posted on Jan 26, 2009
  • 118 Answers
SOURCE: problem with thermostat (honeywell rth111/221).
should be installed with
1) red to rc and jumpered to rh
2) green to g
3) yellow or blue to y
4) white to w
to test: remove t-stat connect white and red - furnace should operate normally unitil you disconnect.
if it does replace t-stat
Posted on Oct 27, 2009
shastalaker7
  • 1515 Answers
SOURCE: my honeywell central heating system turns off on
Hi, Just to let you know I have repaired central Heat & Air systems for 33 years and Have seen this problem on many occasions. Lets see if I can save you so many trips.It says you have a programmable stat? On this stat and on a mechanical stat, they have what is called a heat anticipator that controls how many and how often your thermostat turns you're unit off and on and how long it cycles after the stat is satisfied. If you have ever seen under the cover of a mechanical stat, ( mercury switch type) you will see a dial with an arrow with numbers as .1, .3, .4 1.0, or .15 to 1.0 amps.Some are fixed and some are adjustable. On a digital stat, you will have to get into the program and see what the heat anticipator is set on. They come from the factory at .4, but to really find out what you'res should be it takes an amprobe to do this. The setting you need is what you're gas valve requires.I am sure I have lost you, but I am just giving you a little food for thought. If you can get into you're program and set this to .4, great. If the problem continues, your anticipator on this stat is more than likely, shorted, which would require you to buy a new stat.With a shorted anticipator, it will seem to be working like you say, but when satisfied, the temp.keeps falling until you reset power, then it fires and repeats this. Change the stat. If this is central heat and air, just follow red-rc which will have a red jumper to rh for heat, white to w, green to g=fan, and yellow or blue to y = cooling. If you have central heat only, you will find 2 wires red and white.Red to rh with jumper still installed to rc and then white to w.This is quite a long explanation, but I wanted you to know a little more then the next guy about your stat. Please let me know.
Sincerely,
Shastalaker7
Posted on Nov 12, 2009
My Honeywell T8001C doesn't allow me to change the indefinite temperature hold for some reason
It sounds like the thermostat is malfunctioning; the Set should not be flashing at all, only the Hld should show after pushing the hold button.
Do you have a new battery in the unit? Is it set to Heat or Cool? Is it already programmed for current Time/Date and does it have a schedule programmed in already? If you've lost the user manual it's here: https://customer.honeywell.com/resources/Techlit/TechLitDocuments/69-0000s/69-1431.pdf
Jul 06, 2014 | Honeywell Programmable Thermostat Heater
Honeywell emm-3 goes to high heat when thermostat does not call for heat
Replace it (thermostat), but first make sure its in a good location to read the space temperature.
Nov 29, 2013 | Heating & Cooling
Honeywell th6110d1005
Make sure it's in auto, not manual.
Nov 28, 2013 | Heating & Cooling
At what temperature do I program the thermostat for a comfortable cooling(at how much do set the cool and h ow much should I set the heat). Thanks for your help
Normal settings are heat 70 and cooling 74 to 76 I like 76 if your not active its fine. They say the every degree above 70 heat cost additional 5%.
Jul 02, 2011 | Honeywell Programmable Thermostat Heater
Have gas furnace and this winter,began having
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
However - the problem is probably not with your thermostat but with your furnace. It is most likely a dirty flame sensor - a maintenance issue. If you have not had your furnace serviced recently (more than 1 year) that is where you should start. Modern furnaces require regular maintenance.
Please rate my answer!
Feb 28, 2009 | Honeywell Electronic Programmable...
Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Jan 07, 2009 | Honeywell Electronic Programmable...
Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
Thermostate temperature setting wrong
Are you saying that the temperature over-shoots it's setting by 5 degrees? If so and if the thermostat has an inticipator device in it you can adjust it. After removing the cover on the thermostat, look for a little brass triangle on the lower right hand side. There will be a scale with numbers on it and they are very hard to see. This device heats up prior to shutting off the thermostat so it will not over-shoot by more than a few degrees. Move the brass triangle either up or down and let the heater cycle a few times. If the temperature swing gets worse, go the other way next time.
If the thermostat is not heat inticipated, there will be a small "Dip" switch where you can adjust to a specific degree of under-shoot.
Visit the Honeywell website and you can pull up the installation/owners manual for your model. www.honeywell.com
Nov 27, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
67 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
