Question about Epson EB-450WEDU 2500 ANSI Lumens WXGA Projector 3 Year Lamp Warranty, Education Only
Epson eb-450We will not turn on
Projector has recently had lamp replaced and now is not working properly. It will not turn on in the morning and when it does eventually turn on after 8 tries, the lamp light flashes, and it only lasts an hour before it turns itself off again. I have tried resetting the lamp hours on the menu and this has not worked? Please help.
SOURCE: Projector lamp flashes and the temp red led lights.
Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
Posted on Sep 24, 2007
SOURCE: Won't turn on, only flashes red light
Probably the filter is blocked. Unplug the power lead at the back and leave for about 30 seconds. Plug back in and it should work. The first opportunity you get, buy some compressed air and give it a good clean.
Posted on Nov 18, 2007
dhiman
  • 115 Answers
SOURCE: projector problem - Epson EMP-S1H Multimedia Projector,
try to reset lamp by using menu, up, down and enter buttons. also reset the filter and try again.
Viren
Posted on Nov 27, 2007
  • 11 Answers
SOURCE: Projector epson emp-30 in error
i have one that work but there are red bars on the display, for sale 50.00 no lamp
Posted on Apr 05, 2009
projdoc
  • 2237 Answers
SOURCE: upside down screen Epsom emp s1
if you go into the menu and under settings (or service) you will find an option to reset the settings to factory default. select that.
Posted on Sep 08, 2009
Why epson projector eb-56 not warking red light in lamp
Trying unplugging it and then plugging it back in. Check the air filter to make sure it's clean. If the lamp light is still on, mostly you have a bad lamp. I always buy new lamp from Bulb Source. They have a quick turn around for delivery.
Jun 13, 2014 | Epson Projector Lamp for EB-1830
Projector epson eb-s02 doesn't powr on
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Apr 26, 2014 | Epson Office Equipment & Supplies
Epson eb-s7
competitive price.
any questions, feel free to contact me
have a nice day!
Dec 07, 2013 | Epson EB-G5350 Projector Lamp Replacement
Just got a hanimex sr9000 projector but while running film in reverse it just went dead light and all had to pull bits of trapped film out can i make it work again
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. any questions, feel free to contact me have a nice day! Jerry Lampdeng Limited
Nov 10, 2013 | Epson ELPLP41 EB S6 Lamp
EPSON EB-G5350 service manual
Have a nice day!
Jerry
Lampdeng Limited
Mar 01, 2013 | Epson EB-G5350 Projector Lamp Replacement
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
I have a epson eb-s9 it has started to show a yellow tinge border around top and left of image
the lcd panel is break ,or the polarizer is break ,
competitive price.
have a nice day!
Oct 09, 2012 | Epson ELPLP58 - V13H010L58 Projector...
I have epson eb-s9 projector and when i connect with my pc half of the view its yellow... the projector is new i dont think is a lamp prob... help me plz
Try uninstalling the software for the projector and try installing again. During uninstallation, select to clear all the data created by the software. If it doesn't work, go to google.com and search for support.
Jun 25, 2012 | Epson POWERLITE S9 PROJECTOR
Why does my epson emp 700 projector cut off after ten mins even when the fans are working
These models of projectors form Epson have a standby which the projector enters when it no longer senses video input. The fans will continue to run because they are cooling down the lamp which remains hot for a few minutes after it turns off.
This could be a problem with your computer, or dvd player, or whatever device you are using for your movies. Check to make sure these are working properly. Check to make sure that your dvd player or computer is still outputing video to the projector.
If this does not fix your problem, then the problem could lie with the projector itself. The projector fans may not be properly cooling the lamp, in which case the projector will turn off the lamp to ensure the projector is not damaged. To fix this, you could check if the fan outlets on the projector have become clogged with dust. If they have, definitely clean them out with compressed air.
Hope this helps.
Apr 12, 2011 | Epson EMP-740 Multimedia Projector
Epson EB-450WEDU 2500 ANSI Lumens WXGA Projector 3 Year Lamp Warranty, Education Only Logo
112 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
