Question about Hobart A200 Stand Mixer
I have a Hobart a200t industrial mixer which isn't running properly. When turned on, it just hums, and the gears don't move. I have been searching online and cannot find a free troubleshooting guide. I have checked the Hobart website, and their troubleshooing guide is unavailable. Does anyone know what the problem might be or where I can find a free troubleshooting guide?
    Novelist:
  • 125 Answers
Hi, it is hard to determine exactly what the problem is without seeing it, however, that mixer usually uses a capacitor to help start the motor, and a switch, or relay, that are in the back of the unit. You probably will not find any troubleshooting guide, Hobart does not give up information easily. You can take it to an electric motor repair shop, and they will easily be able to tell which of those is the problem, and will be reasonable in price. Your other option is to contact Hobart locally for service assistance. Maybe one of the other Hobart techs here can help you out more.
Posted on Jan 04, 2009
Hobart A200 won't start
If the gearing is all free to move and you replaced the motor capacitor that only leaves the motor. If you can remove the motor and test it "out of the gearing" that would confirm it. You have wired the capacitor correctly and used the correct one? Just asking! Are you sure the gearing isn't jammed up?
May 13, 2014 | Hobart A200 Stand Mixer
Hi, I have a used Hobart A200T and the bowl yoke piece moves up and down slightly, even under a light load. It makes an annoying clanking noise. It's as if a spring somewhere is looser than it should be....
You may be correct about a loose spring. Check this:
Carefully lay the mixer on its back side to access the bottom of the mixer. Remove the cover screen covering the opening in the bottom of the mixer. Using an extension and appropriate socket, be sure the nut of the bowl lift rod is snug, slightly compressing the spring of the bowl lift rod.
Jan 26, 2011 | Hobart A200 Stand Mixer
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
A200T Slips in low and medium speed
Planetary gears worn from, #1 changing speeds while unit running, #2 over loading the bowl. batter & icing max 75% bowl capacity, Dough max 65% bowl capacity
Jul 17, 2009 | Hobart A200 Stand Mixer
I need the manual for the Hobart 20 Quart Mixer A200T
Hobart doesn't release their service manuals to the general public,however i'm a hobart tech and repair these mixer's often.If you need any help let me know.
Mar 05, 2009 | Hobart A200 Stand Mixer
Hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Jan 03, 2009 | Hobart A200 Stand Mixer
Sound like bearings
Ist check your agitator shaft for looseness. the shaft you put the beater on. wiggle side to side. if tight no play. If in first its quiet but you can here a grumble under load but second gets louder. and third even louder. If the shaft is tight. your gears down there are warn. you can take that all off with the two nuts underneath. and check the grease on the gears but even with new grease on them it most likely stay loud. grease it with hobart grease from your loacal hobart for the A-200 planitary not the transmision they also fve grease for Trans. if you can take the noise run it that way if not decide which arm & leg you want to give hobart for new gears.
Sep 10, 2008 | Hobart A200 Stand Mixer
A200t ist gear
This is a lousy diagram for your purpose ...
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
Page 14. The spring goes on the right with the hump against the roller.
Mike
Apr 27, 2008 | Hobart A200 Stand Mixer
Mixer has just stopped
On the newer A200s, there is a reed switch behind the solid portion of the bowl gaurd. On the cage portion there is a magnet embedded in a plastic holder. Without it, the mixer won't run.
Hobart part # 438525
Apr 04, 2008 | Hobart A200 Stand Mixer
A200T HOBART MIXER
is there a bowl cage on the mixer?if not bypass the timer and see if it starts.
Oct 19, 2007 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
517 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
