Question about Linksys Wireless-G WRT54G Router
How to change mtu settings on windstream safem fast 1704 modem/router
4 Suggested Answers
Ap12
  • 107 Answers
SOURCE: XBox 360 MTU Failed with Router
MTU of 1500 is the standard TCP/IP message length. Only MS Vista allows that to be changed dynamically. If your ISP uses 1500 then you need to use it too. Your Xbox protocol may be blocked by your ISP. You may want to give them a ring...
Posted on Jan 04, 2008
kap990
  • 28 Answers
SOURCE: MTU setting
  • Connect to the Router by opening a web browser and entering http://192/168.1.1 or the IP address of the Router.
  • Enter the password if asked (default is "admin").
  • Click Advanced and select the Filters tab.
  • Look for the MTU option and select Enable. In the Size: field, enter the appropriate MTU (e.g. 1492).
  • Click the Apply and Continue buttons to complete the task.
  • u can chk routers ip address by opening command prompt and typing ipconfig and press enter it will show u the ip address of the router.
  • Posted on Jun 25, 2008
    Nerdy_geek
    • 94 Answers
    SOURCE: 360 mtu test keeps failing
    Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
    then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
    to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
    Posted on Sep 13, 2008
    Ipad2 dropping connection. I have a Sagemcom 1704 n modem. Laptop and iPhone working great.
    if you have dual band,use 2.8 ghz instead of 5.6ghz,or the power adapter to your modem is not giving enough power,also update your ipad by searching for updates
    Apr 20, 2015 | Computers & Internet
    I need an open nat on my sagem 1704 router for ps3 game mw3
    I did it with Xbox.
    Manually configure your console to have a specific IP address. I set my XBox to 192.168.254.254, with the subnet of 255.255.255.0 and the gateway of 192.168.254.254.
    Then (on a computer) I opened my web browser and went to the address: 192.168.254.254
    The name and password are both: admin
    I clicked Adcances Settings, then NAT, then Virtual Servers.
    I created a virtual server, named it, gave it the IP address of my console, and opened up the appropriate ports.
    Once I saved it, it worked fine.
    How to configure Windstream st 1704N dsl modem router for Xbox live NAT
    Apr 02, 2012 | Computers & Internet
    How do i get my windstream modem 1704 wireless light to come on
    Log onto your modem interface, 192.168.254.254, logon un admin, pw admin, then wireless , then basic, there should be a check mark in the first box listed, click the box, if there is none, then click on save/apply button.
    Mar 04, 2012 | 2wire Computers & Internet
    Where do you go on the ladtop to change mtu settings
    You cannot change the MTU settings in the laptop. You will have to log in to your modem/router using your laptop(when modem/router is connected through a cable).
    Hope this helped.
    Jan 29, 2011 | Arris SURFboard SB5120 Modem
    My status light just blips and i am unable to browse the internet
    With some older Cable modems there may be speed negotiation problems, you will see the WAN LED on the router flashing really fast as soon as you connect the Cable Modem to it.
    To fix the problem you need to turn both the modem and the router off (unplug the power cable). Then turn the modem on first. After that turn the router on. After that the two devices will autonegotiate the link correctly.
    Note: If you see WAN light flashing rapidly and one of the LAN lights flashing fast as well, such behaviour is due to network traffic going in/out the router. Exessive traffic may be related to virus or trojan infection on one of the computers on your LAN.
    You might try lowering the MTU value on your router. The MTU can be changed to accommodate fragmentation of packets; specially encoded packets with secured data can be too large for the current MTU and cause too much fragmentation.
    Or:
    Step 1 Open your browser, enter the IP address of your router (192.168.0.1) and click OK.
    Step 2 Enter your username (admin) and leave the password field blank, which is the default password. Click OK to enter the web configuration page for the device.
    Step 3 Click on the Home tab and click on WAN on the left side.
    Step 4 The default MTU rate is 1500, to change this enter the number in the MTU field and click the Apply button to save your settings. (Start off with 1452)
    Step 5 Test your ability to connect to those specific sites you're having trouble with. If changing the MTU rate to 1452 does not resolve the problem, start lowering it in increments of ten until the problem is resolved (you may need to go as fairly low depending on your DSL connection).
    If you do not have this option, please upgrade your firmware at http://support.dlink.com/downloads
    Nov 05, 2010 | D-Link AirPlus DI-524 Wireless Router
    I want to change the MTU setting to 1364
    Cablemodems are bridge devices the MTU setting you are looking for would be in your OS or router (easier to set on a router though).
    checkout http://help.expedient.com/broadband/mtu.shtml
    Oct 15, 2010 | Arris SURFboard SB4200 Modem
    How to use bellsouth router on windstream internet
    yes you have to configure it with the dsl modem plug your modem ether net cable into routers ethernet,open your modem configuration page by typing 192.168.1.1 login by using by default the router login are "admin"and pass word is also" admin" note down dns setting and other setting which yopu may need tosupply the router now open router login page and supply required connection setting change set router default address 192.168.1.2 soit should not conflict whith each other supply dns setting, enable wireless ,set wireless secuirty ,try now sitehr@gmail.com
    Aug 16, 2009 | Westell Wirespeed VersaLink...
    Have the n+ wireless router/modem trying to connect via a cable to xbox live but keep gettin insufficient MTU even though the actual MTU of the router is higher than required
    You may have to use trial and error to find the best MTU fit:
    MTU Default of 1500 to 1492
    Tart the setting the MTU @ 1400
    MTU setting. Xbox LIVE requires a minimum MTU setting of 1364.
    The information your console sends and receives is broken up into "packets" for transmission over your network. MTU is a setting that controls the size of these packets. If it's too small, you won't be able to connect to Xbox LIVE.
    Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
    Solution 1: Check your router MTU settings Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
    Learn how to find and use your router configuration page
    Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
    Solution 2: Connect directly to the modem If your router's MTU is set correctly, try bypassing it by connecting your console directly to the modem. This will help determine whether there's a problem with your router or something else on your network.
    Note
    This may require you to move your console to a location close to your modem. This is a temporary arrangement, meant only to troubleshoot your connection. If your console is connected wirelessly, you'll need an Ethernet cable for this step.
    To connect your console directly to your modem (wired connection):
    1. Find the Ethernet cable that runs between your console and the router.
    2. Unplug the cable from the router, leaving it connected to the console.
    3. Find the Ethernet cable that runs between the router and the modem.
    4. Unplug the cable from the modem, and plug the cable from your console in its place.
    To connect your console directly to your modem (wireless connection):
    1. Unplug the USB connector for your adapter from the console. The adapter can remain attached to the console.
    2. Plug an Ethernet cable into the Ethernet port on the back of the console.
    3. Find the Ethernet cable that runs between your router and the modem.
    Try to connect to Xbox LIVE again. If it works, there may be an issue with your router. Double-check the MTU setting in solution 1 above. Also confirm that you're using a compatible router, and make sure it has the latest updates from the manufacturer. If the problem persists, you may want to try a different router.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    May 06, 2009 | Belkin N1 Vision Router
    Sep 13, 2008 | Linksys Wireless-G WRT54G Router
    Linksys Wireless-G WRT54G Router Logo
    278 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
