Question about Mr. Heater Portable Kerosene Heater - 175,000 BTU
I bought off a friend imr heater 175,000 torpedo heater some times the flame will shoot ot a puff of smoke
I bought off a friend he mixed deisal and kerosene my problem is that it will cut out and them a puff of smoke comes out\ .i got rid of the deisal fuel and put in kerosene it burns cleaner (at least my eyes arnt watering) the htr doesnt die it just shorts out for a second or two followed by a puff of smoke i was told a filter change could help
5 Suggested Answers
SOURCE: I have a a problem with my mr. heater. When I turn it on it puffs
Not knowing what Mr Heater Model you are referring to, I would suggest you call Mr.Heater's customer service line at 800.251.0001.
They have techs that can help troubleshoot your problem.
Posted on Jan 13, 2010
SOURCE: MH75KT Contractor's Series Kerosene Heater won't stay lit
Heater will not lite
Posted on Nov 16, 2010
Audioaholic
  • 376 Answers
SOURCE: just replaced the ignitor on my mr heater because
well for one it should have (kerosene) in it and not diesel. two you need to clean out the pump and lines as well . it should have a spray pattern, not drips. sounds like wrong fuel and or not enough pump pressure.
Posted on Jan 06, 2011
  • 259 Answers
SOURCE: Hello, I hope you can
Take a thin wire and check the holes in the burner to make sure they are not plugged up. Also check where the hose
Posted on Mar 27, 2011
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
Starts and quits puff of smoke comes out 60000 btu
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 16, 2011 | Heating & Cooling
Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 30, 2009 | Reddy R60A Utility Heater
70,000 BTU Reddy heater - runs - but it puffs smoke
heatman101
Dec 28, 2008 | Reddy Heater-30-55,000 BTU Variable
Mr. Heater Portable Kerosene Heater - 175,000 BTU Logo
119 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
