Question about Quantaray QDC-NK i TTL Digital Flash Module (D70/D50) Flash
Will a D3200 nikon camera operate safely with a QTB- Quantaray flash?
maunderer
  • 5 Answers
SOURCE: Quantaray QDC-NK i TTL Digital Flash Module
The Quantaray Digital NK Module has a small tab on the side of the raised boss that the 8 pins sit on that prevents it from mounting on the QTB-9500A. It's intentional- the NK Digital Module is made for newer Quantaray flashes only. You'll need the older-style AF NK Module to attach to the QTB-9500A.
Posted on Aug 22, 2009
  • 12 Answers
SOURCE: My Quantaray QTB 7500A will not turn on. Placed
Make sure your batteries are inserted properly (+/-) Slide the battery cap on and off several times to make sure you have good contact.
Posted on Oct 26, 2009
Obertelli
  • 3006 Answers
SOURCE: Quantaray QTB-9500A with Canon Xsi not working properly
This is probably way too late for the original asker, but the previous answer is incorrect.
The Quantaray QTB-9500A is in reality a ProMaster FTD-5700 and was designed for use with later model electronic 35mm AF models (using the correct dedication module).
As such, the trigger voltage is no higher than 5v making it safe for use on later digital SLR's.
The original answerer is clearly aware that high trigger voltages on flashes designed for earlier, mostly mechanical, 35mm film cameras are often harmful to later models, but you need not worry about your model.
Please take a moment to rate my answer.
Posted on Feb 15, 2010
  • 11 Answers
SOURCE: Nikon D300 and Quantaray Flash...
I use their products and have had great success as well as great response. I don't have the Quantaray, but if you contact them they will most likely have a direct solution for that flash.
http://www.flashzebra.com/products.shtml
Posted on Apr 01, 2010
SOURCE: I have a quantaray qtb-7500a speedlight. It is for...
There are modules available to convert the camera into a Nikon lens. Right below your fill flash on the left hand side of the unit, there is a square button to release your current module and attach the new Nikon module.
Posted on Nov 29, 2010
I bought Canon EOS d700. I have a Quantaray QTB-9500A with AF Module NK with my NIKON D90 . is this flash works with Canon EOS d700?
It will work, but not all functions will be availale. You can buy a Canon module for the flash.
Jul 11, 2017 | Canon Cameras
I have a quantaray qtb-7500a for an older n80 nikon but i want to use it with my d90 it has a af module nk
The QTB 7500A will work with the D90. However, you will not be able to use the iTTL mode of the D90. Use it exactly the same way you've been using it with the N80, letting the flash control the exposure.
May 10, 2011 | Quantaray QTB-7500 for Nikon TTL Flash
I have a quantaray qtb-7500a speedlight. It is for a Minolta camera. Is there any way to adapt it to fit Nikon equipment? jim
May 20, 2010 | Quantaray QTB-7500 for Nikon TTL Flash
Will my qtb-9500a work on hotshoe of canon digital rebel 350
Yes. The trigger voltage is typically less than 5v so it is safe to use.
See here for further info.
Please remember to rate my answer.
Dec 26, 2009 | Quantaray QTB-9500A TTL Flash
How can I get the Quantaray QTB-9500A to work with the Canon rebel XT? It worked fine with my ellanIIE. Can I order a new module? Thank you for the help
You'll need the "AF module CN", but as the flash is no longer made will have trouble finding one.
It helps if you search for the correct flash model as Quantaray is a no-name bit of badge engineering for Ritz/Wolf.
Your flash is really a ProMaster FTD5700.
Please don't forget to rate my answer.
Sep 25, 2009 | Quantaray QTB-9500A TTL Flash
Aug 31, 2009 | Quantaray QTB-7500 for Nikon TTL Flash
Aug 30, 2009 | Quantaray QTB-9500A TTL Flash
Apr 06, 2009 | Quantaray QDC-NK i TTL Digital Flash...
Quantaray QDC-NK i TTL Digital Flash Module (D70/D50) Flash Logo
60 people viewed this question
Top Quantaray Cameras Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
