Question about Brother MFC 4820c All-In-One InkJet Printer
Help I have a brothers mfc 4820c printer 7 in 1, and every time i turn it on all i get is error 41, and it wont let me print fax or copie.
  • manderson832 Jan 06, 2009
    I have used Brother ink since new and tried cleaning the printhead without removing it. Is there an easy way to get it out and clean it better? Thanks, Mike
  • 385 Answers
Hi, Unfortunately, this is caused by the printer head. It will gradually stop working. However, some things to try is to clean the print head. This is literally opening the printer and cleaning the head. Also, avoid using refill ink cartridges as they damage the print head a lot quicker. Get brand new cartridge if you are using refills. If this still doesn't help, then the print head have already been damaged and need to be replaced. By the way, if this printer is still under warranty, brother should replace either the printer or the print head for you free of cost.
Posted on May 16, 2007
Error 41 brother all in one :Performed Print Quality Check Sheet $ times. The test sheets became closer and closer to being 100% correct, then error 41 pops up
Machine error 41 is "defective print head".Try to turn off the printer and wait 10 min.Then turn on, if the error continue showing your printer need service.
Oct 13, 2009 | Brother MFC 420CN All-In-One InkJet...
Code error 41
Error 41
The head drive voltage has not been turned from Low to High within the specified time.
Check:
Carriage ASSY
Main PCB
Print head unit
Power supply PCB
Feb 27, 2009 | Brother MFC 3820CN All-In-One InkJet...
Error 41 MFC 3220C
WELCOME TO THE ERROR 41 DELIMA. YOU WILL NEED A NEW PRINT HEAD, MAY BE U CAN BUY ONE FROM A BROTHER DDEALER AND INSTALL IT GOOD LUCK
Jan 27, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Printer jammed during printing 2nd page and now says ERROR 41 contact brother..MFC 3100c
Dear Soniadux,
Error 41 -The head drive voltage has not been turned from Low to High within the specified time.
Check:
� Carriage ASSY
� Main PCB
� Print head unit
� Power supply PCB
cleaned the print head and try again .
cheerup
Mar 18, 2008 | Brother MFC 3100C All-In-One InkJet...
Brother mfc 420 cn
if you have an error 41 the machine wont print any more due to a short circuit in the print head.
plz check error message.
anyway, if you have received error 41 you need a new printhead or better (because its cheaper) a new mfc.
sorry!
Feb 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Printer- mechanical error 41
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usually just after warranty has expired!
Feb 12, 2008 | Brother MFC 4820c All-In-One InkJet...
Machine errror 41 of brother mfc 3100c
Error 41 is common problem for all Brothet MFC printers.
To fix it, you have to change the Print heads of your printer.If your printer is still under warranty, call Brother 1-800-276-7746(Voice) 1-949-859-2272 (Fax)
and get yourself a new Printhead "free of cost".
Feb 11, 2008 | Brother MFC 3100C All-In-One InkJet...
Brother MFC 3220c machine error 41
I had the same problem with a Brother MFC3420C after replacing the print head with a new one the same error 41 occured 4 weeks later.
I finally fixed the problem (see photo's) and sent the parts back to Brother :-)
Don't buy Brother Inkjet technology its all ****!.
Their laser technology seems to be much more robust and reliable, have had a Brother HL-1440 since 2004 and its still running well.
http://www.flickr.com/photos/48446421@N05/sets/72157623635891898/
Jan 12, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Wont print anything
Move the ink cartridge carriage (the printhead) to the middle of the printer like you're going to change cartridges.  Take out all the ink cartridges.  There should be two black springs on either side of the printhead.  Remove these and the printhead should pop out.  Clean the nozzels (the little parts that squirt out ink) and reassemble.
If this doesn't work, then you'll have to replace the printhead.
Oct 28, 2007 | Brother MFC 3100C All-In-One InkJet...
Error 41
Error 41 means that the printhead is defective and has to be replaced by a new one. The internal piezo-electric is rotten. Sorry, no way to repair the printhead. A new printhead is more expensive than a new mfc
Sep 30, 2007 | Brother MFC 4820c All-In-One InkJet...
Brother MFC 4820c All-In-One InkJet Printer Logo
136 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
