Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I can't read my data traveler.any way to solve it.
  • Kingston Master
  • 27,725 Answers
A few important bits of information about using faults and fixes on usb drives
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see
click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box
(I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive
also you might need to do this
click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hope this helps
Posted on Oct 30, 2012
My Sony Vaio SVE15129CAB can't read Sandisk USB flashes
Are all your Windows Updates Current, up-to-date? What is the file/data format on the flash drive? If you open the Computer folder is the Flash drive there? On other Laptops what opens the data on the Flash drive? The software? Do you have the same software?
Apr 04, 2013 | Computers & Internet
How do I change the temperature reading from Celsius to Fahrenheit?
with the switch in the 'lock' position, hit the C/F button (also labeled as the 'min' & 'date' button)
Dec 30, 2011 | Elgin Travel Alarm Clock
Purchased 128GB data traveler and when i put something on it such as movies outta of the 10 or 15 ive tried only one plays anything else ive put on it never will play music or data or movies is data...
No, if the traveler would have been bad you wouldn't have been able to put the files on it. The files you are trying to play need special codecs that the player doesn't have.
Aug 02, 2011 | Kingston Computers & Internet
Anything I load on to my kingston data traveler 32GB dt101 gets corupted & does not open. I attempted top reformat however problem persist.
the ram chips have become corrupted, either from pulling out the data traveler when it was working, in a folder, and or windows was still accesing it even though it has said it is safe to remove. If this is still under warranty then send it back to get it replaced. I have a couple of 32GB and 16GB thumb drives that have become corrupted just because windows didn't recognise them properly and just kept on accessing them continuously. Sometimes reformatting will fix problem as a short term fix. Just get it replaced ASAP.
Jun 19, 2011 | Office Equipment & Supplies
Unable to save delete or format datatraveler 8GB key. It also seem to have a virus which I have so far not been able to clean. Plese I need your help.
exactly the same thing has happened to be before, but I was able to solve the problem using Avira Anti-virus.
Here is what you have to do to get your flash drive working again;
Install Avira Anti virus on on your computer. If you don't have Avira anti-virus software, go to www.avira.com, on the Avira home page, you will see Free download. Click on the free download. Allow the software download on your computer. Go to the location where the software was download and click on the software to have it installed on your computer.
After the Avira nti-virus has been successfully or completely installed on your computer, insert the data-traveler 8GB into the USB port of your computer.
The moment the data-traveler 8GB is inserted, the Anti virus will pop out with a dialogue box alerting you about virus detected on the data-traveler 8GB.
Select 'Delete...", and the box might pop out over and over. Just keep selecting delete until the whole virus is deleted from the data-traveler 8GB and your flash will be okay.
You can format the data-traveler 8GB thereafter or right click on the data-traveler 8GB from 'My computer' and scan the drive with Avira anti virus.
This should fix the problem you are facing presently. But if it does not solve the problem, please let me know so that I can give the next step to taking.
Your sincerely.
Elect_Comp.
May 23, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When i connect my usb and error will appear "you
LOGON WITH ADMINISTRATOR RIGHTS & CHEK FOR PRESMISSIONS AS YOU CLICK PROPERTIES -PERMISSIONS.
Feb 04, 2011 | ASUS Eee 4G Notebook
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
Top Kingston Computers & Internet Experts
Cleverer2
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
