Question about Cell Phones
My straight talk LGL55C powers up and goes to the blue tracphone blue screen and won't power off with power button or anything
Phone stuck on blue screen won't boot up
Take the Battery out.
Place it back in.
Press and hold the Vol down : Home : Power buttons simultaneously for 10 sec.
Using the volume buttons navigate to the reset to factory settings option.
press select (left of home on L55C).
Confirm to reset.
Select to reboot.
You should be good.
Posted on Mar 12, 2014
bigjohn007
  • 425 Answers
SOURCE: No response from keypad input?
check your volume keys or any side keys that get stuck... or if you can open your fone check its keypad for any shortage...
Posted on Oct 26, 2007
Bajanguru
  • 7752 Answers
SOURCE: my motorolav3m razor phone is on the fritz
you need to take the phone to a mobile service center and hvae them correctly install the firmware back on the phone
Posted on Dec 28, 2008
  • 55 Answers
SOURCE: When I turn on my Motorola W385 it goes to a blue screen
if your phone ask you for a code just dial 000000
Posted on Mar 25, 2009
SOURCE: my razr phone shows a blue screen with bootloader usb init at the bottom. I have tried pressing the power button at the same time as the # and * buttons and holding them down, but it doesn't work. Whe
you used a regular usb cored. i had the same problem you have to send ut in to get a new one its broken you need a dat cord hope i helped
Posted on May 28, 2009
  • 437 Answers
SOURCE: my phone is stuck at
soohyungi Hi it sounds like the phone was doing a software update and it crash . You may be able to get it working again by taking out the battery but not put back on the phone, Plug the phone into the charger. Next I need you to look at the contacts on the phone see if they have any corrison on them. Now take a clean tooth brush one that hasn't been use. CLEAN the contacts and the charging port area . See if there is any dirt in the phone.If you can't get the phone to work go to a verizon corp store and let them take a look at it for you . Software crashes ocurr when thwe phone is in the middle and someone calls you . Hope this helps
Posted on Nov 28, 2010
How do i turn off my phone? When i went to Tracphone app it is stuck on that site and can not touch anything to make anything on screen move and it will not turn off.
If you have not removable battery try this: hold down power button more than 3 second and in menu touch 'reboot'.
Feb 04, 2016 | Cell Phones
Any tricks to turn on my LG840G with broken power button
Plug in phone, and remove charger as soon as, or right before phone turns on, then constantly press buttons on bottom of the screen.
Jul 02, 2013 | Straight Talk LG840G Cell Phone
Hi samsung gio won't start stuck in first samsung screen and can't log to recovery mode it gives ramdump and stuck
ram dump if your press vol up+power+home button, but if you wanna go to download mode you must press vol down+home+power button.
it stuck on first screen called boot loop, solution is reinstall or flash new rom on your phone,
follow this http://www.droidvan.com/2012/06/link2sd-on-stock-rom-s5660dxkt8-236.html if you wanna back to stock rom
or this http://www.droidvan.com/2013/03/cm-9-final-for-galaxy-gio.html if you wanna taste off ICS on your phone
Mar 12, 2013 | Cell Phones
My phone will not power up past the tracfone blue logo screen what should i do??
The below steps will resolve many small issues.1.Power off the phone.
2.Press and hold "Vol+", "Menu", and "Power" key until the phone goes to recovery mode.
3.Use "Vol+" and "Vol-" to move the cursor up and down.
4.Move cursor to "wipe data/factory reset", press "Back" key to select it.
5.Now move cursor down to "Yes - delete all user data" and press "Back" to select it.
6.The data will be erased.
7.The cursor will be on "reboot system now" at the end, so just press "Back" key to reboot the phone normally.
WARNING: All user data will be completely cleared; the phone will be in a factory reset status.So before you reset backup data first!! gud luck!!
Feb 23, 2013 | ZTE Cell Phones
My LGL55C powers up and goes to the b lue screen n won't boot up or do anything won't turn off .
Dear Chris,
Seems like a bad RAM. Simply change your RAM and then give your laptop a go and it shall be all fine and smooth sailing on wards. You can test it by simply borrowing a RAM from your friend for a while. But do make sure that RAMS are of same type.
Oct 30, 2012 | Computers & Internet
My vivaz won't come on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 19, 2012 | Sony Ericsson Vivaz Cell Phone
How to add apn for sgh a597 on straight talk
AT&T phone on Straight Talk (sprint)? Unfortunately, AT&T uses GSM which is not compatible withSprint's CDMA technology.
Straight talk runs on the Sprint network, same as Boost and Tracphone. Although some phones are the same, some only work on certain networks.
Sep 04, 2012 | Samsung sgh-a597 - Sgh-a597...
Iphone4 screen goes blue and won't shut off
Hi
Try hard resetting it.This procedure may erase all changes effected on the i phone
Press and hold the power button and the menu button.Wait until the apple logo appears.
Feb 19, 2012 | Cell Phones
Wont go into phone mode
Assuming you've tried pulling the battery and booting it again, you could try doing a hard reset on the phone (this would erase all data on the phone), by starting up the phone while holding down the volume up button while turning the phone on, waiting until you get a white screen with 3 skateboarding androids on it, and select clear storage (use the up/down volume buttons to move the cursor, power button to select), then volume up to confirm. If the phone still won't boot up after doing that, you're going to have to take it to a store, as that boot menu is the only thing that you can get to come up if it won't boot all the way up.
Nov 10, 2011 | HTC EVO 4G Smartphone
Cell Phones Logo
244 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
