Question about Kitchen Ranges
I have a Magic Chef range. My baking element in the oven caught fire and broke in half from the heat. I am trying to replace the element but am not sure if I am supposed to disconnect the element from the yellow wire in the oven at the clamp or if there is another way.How should the baking element be removed?
  • 163 Answers
Hi!!! All you have to do is go and buy a new heating bake element..turn off the power to the oven by the home breaker..then move the oven away from the wall and remove the back panel screws and look for the baking element it has 2 wires going into it.Very easy to fix..good luck..
Posted on Jan 03, 2009
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Oven element burned through into half, what do i do?
Here is that element to order. There is also a video on that same page to show you how to make the repair.
GE WB44T10011 Oven Bake Element AppliancePartsPros com
Apr 03, 2014 | GE JBP82 Electric Kitchen Range
What is the complete model number of your unit? Look inside the door area.
Nov 28, 2012 | Magic Chef Kitchen Ranges
The oven won't heat on bake
Hi,You have inspected both the baking and broiler heating elements, and you still can't find a problem with your range/oven parts? Inspect the connections between the heating element and the terminal. You could have a badly connected electric wire, or a burned out electric wire. Range/Oven parts must deal with both voltage and extreme heat, so it's a common problem to have a burned wire from time to time. This is a simple fix and if you check this problem in your initial run of troubleshooting, you may save yourself unnecessary purchases of range/oven parts, etc.
Also Voltage Check can be the problem.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral, both should be 120 volts.
Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out
Check the power at the terminal strip.
Be careful as 240 volts is lethal !!!
May 25, 2011 | Magic Chef 31000 Gas Kitchen Range
I have a magic chef range/oven. For the last few months, it has taken longer and longer for the oven to heat up to temp. Now it won't get more than 90 degrees or so. What is the problem??
Turn off the power to the range. Remove the bake element from inside the oven. Be careful not to let the wires go back into the oven cavity. Take a volt/ohm meter set for ohms or continuity and test the bake element leads. If you get no reading replace the element. If you do get a reading,replace the temperature sensor in the oven.
Oct 08, 2009 | Magic Chef Ovens
Oven doesn't work after replacing the bottom (baking) element
Will the clock control accept the bake and temperature request?
If so,
You will need to remove the rear panel of the range and test the bake element leads for 220 volts when the oven control is set to bake and is turned on.
Mar 08, 2009 | Magic Chef CER3725AA Electric Kitchen...
What is age span of stove?
I was using a 1938 model in an apartment unit and only replace it for the looks. Electric heating elements are cheap and relitively reliable..
Jan 02, 2009 | Magic Chef Ovens
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
funny same thing just happened to me and it all seams to be the bottom element of the same ovens around the same year, I bought mine in 99 also, I keep my oven very clean becasue i know the dangers it may cause, I think this is a major problem and it needs to be addressed.
Aug 19, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
204 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
