Question about Garden
Hydraulic fluid is leaking out of the boom on my pitman / polecat p45 digger derrick
I am in need of a owners manual for my 1990 P45MH 4T digger Derrick Boom Truck. Gross lifting Capacity is 20,000lbs. Book higth is 45' its a 3 stage boom with the third stage being fiberglass. The 2nd stage hydraulic cylinder is leaking and I need to understand how to remove this cylinder from the inside of this enclosed boom. My email address is charles@duncanmarineinc.com , my cell # is 910-520-5060 please call or email me with any help or suggestions you may have. Thank you much. Charles Duncan
  • 77 Answers
SOURCE: apple ipod M9244LL owners manual
Look here:
http://www.apple.com/support/manuals/ipod/
Posted on Jan 29, 2008
  • 6982 Answers
SOURCE: V-6 1991 Rodeo clutch remains engaged after
Ive never seen a slave cylinder get stuck. there is a lot of force against it from the clutch diaphram, but there is a first time for everything!! I have seen diaphrams on clutches go bad and "over-center" when depressed. watch the slave and see if its staying extended (unless yours is located on the throwout bearing and you can't see it) If it's on the outside of the bellhousing, you can easily change it if its bad. If not the transmission needs to be removed to get to it.
Posted on Apr 21, 2009
canbruce75
  • 1776 Answers
SOURCE: Jayco lift system cable replacement
Try this link and see if it will help you any with the info that you need. Sure hope this helps you find resolution to the problem. Best wishes.
http://www.ehow.com/how_4708883_repair-jayco-camper-cables.html
Posted on Jul 23, 2009
SOURCE: JCB 801.4 mini digger - no control of digger arm
We have a similar problem on a Mitsubishi MM55SR.
We developed a new control set-up
Posted on Aug 07, 2009
SOURCE: Mss-SR Mitsubishi excavator moves and lifts lowers
I think I can help you with it. Last year I had similar situation with my MM55-SR flashing red CPU light. The arm stopped moving, but the blade was working and I could drive as well.
I inspected all position sensors in the arm - each joint should have one. They look like small cylinders bolted to the joints of the arm with 3 wires coming out. In my case I had problem with the first sensor located by main (boom) piston where it is attached to the body of the machine. I removed this sensor from the arm with its wire. One wire was broke very close to the sensor housing. I was able to solder it and it solved my problem. Sometimes those wires can touch to the metal arm and rub off insulation causing electric shortage which also may stop the arm from moving. Check all connectors and wires for each position sensor first.
Hopefully this will help solving your problem.
If you want to share your experience you can email me at lferenc@hotmail.com
Posted on Aug 20, 2009
1990 Honda EX clutch. It does not ingage. It pops to the top or sticks to the floor
Not sure of the model EX, but it probably has a clutch hydraulic slave and master cylinder that has leaked out the hydraulic fluid. Fill the clutch master cylinder (near the brake master cylinder) with brake fluid and pump the clutch pedal several times. The clutch work again until the fluid leaks out, so the permanent fix is to replace the master and or slave cylinders and bleed the system. Other models have a clutch cable that would need replacing in this case
Oct 24, 2017 | Honda Cars & Trucks
I have an old UHO 83 digger. The problem is that when I walk the digger it moves about a metro and stops, when i release the lever and push it forward it will move again and then stop again until the lever...
i used to know some one that had a hitachi. was always having problems with it not moving. if i remember right it was the brake leaking think its air system and it was just leak. he had it fixed and added an air line indicator fitted think the boom works on the same system. if i remember right there is a foot brake and a lock brake lock brakes hydraulic . and the normal braking. but in the event of the air brake falling the hydraulic brakes take over. but this is from memory and it was a long time ago you dont see meany round here any mor they all jcb's and other makes.
Mar 24, 2014 | Cars & Trucks
Excavators boom
Is the machine leaking any fluid?
Jun 19, 2013 | BIT EA10F Earthquake Earth Auger Bit 10"...
EX58Mu hitachi Excavator will not lift main boom arm all other hyd actions work well
Is it leaking any fluid. Spool valve may have a blown seal.
Jan 29, 2013 | Garden
The hydraulic steel line on my 2010C bucket loader broke and I dumped a good amount of fluid before shutting everything off. Replaced line and filled tank up, everything worked fine for about 1/2 hour,...
Like other hydraulic systems, there is probably a procedure for bleeding the lines after loss of most of the fluid. You may still have air trapped in the system and once it works its way to the cylinder, the cylinder is working with air instead of fluid and the air compresses instead of doing work.
Sep 16, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My 94 chevy s10 blazer is leaking power steering fluid pretty bad from the lines or pump itself. How many lines are there for the power steering pump.
the main one is the feed which is pressurised and the main cause is the flexible rubber pipe ,they perish and go porous ,take this pipe off and have the rubber part replaced in a hydraulic type place that does industrial type work ,might cost 20 euros if that
Aug 01, 2010 | 1994 Chevrolet S-10 Blazer
Any idea how to top up hydraulic fluid in old mini digger pel job eb10
Fill it where the hydraulic filter is in the tank .
Nov 15, 2009 | Garden
I have an old Ford 550 digger clutch failure
if its a hydraulic clutch & conneted to the same system & its low on fluid then that will be your problem
just top it up & try it you may have to bleed out the system of air if it doesnt work!
Jul 19, 2009 | San d Digger
Garden Logo
278 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
