Question about Kenmore 73952 Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
Whirlpool model LGC66466AWO gas dryer pilot light is off upon starting the dryer. About 15 - 20 seconds later pilot will light and flame goes on. One minute later the flame and pilot go out. The one minute after that pilot goes back on and flame starts again. This is all occuring while drum is spinning.
  • 1 more comment
  • Anonymous Mar 22, 2014
    Dryer turns on, pilot heats up, flames lights up but only burns for about 10 seconds. Then goes out. What's wrong?
    Dryer turns on ok. Pilot heats up, and gas flows because flame lights up. Problem is the flame only burns for about 10 seconds. What's wrong?
  • Anonymous Mar 30, 2014
    Flame lights, but goes out after 3 seconds
    Problem Solver:
  • 14 Answers
Should have electronic igniter that light gas after turned on.
Posted on Jan 03, 2009
Burner lights and goes out
It may may be the safety system for pilot light is maladjusted. There is a sensor which has to be heated by the pilot light or the valve shuts down altogether. If the pilot light stays lit then you check to see if it is positioned to light main burner.
Jan 26, 2014 | Whirlpool Dryers
My whirlpool gold dryer doesn't have any heat coming from it. Could my pilot light be out?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 19, 2011 | Whirlpool Dryers
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
heatman101
Aug 28, 2011 | Whirlpool Dryers
The dryer starts,heats up,gets good and hot,heat kicks off,electronic pilot kicks back on but does not light. runs cool from there on even as pilot continues to try and light.
heatman101
Aug 21, 2011 | Whirlpool Dryers
Do we need to light a pilot light in order to start the dryer? how do we know what year the dryer is?
No pilot light just a hot surface ignitor that starts the fire in there...
get the model and serial of your dryer and then do a search for the year... it will come up...
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | Dryers
Pilot light goes out about 2 minutes after starting dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 25, 2010 | Whirlpool LER4634J Electric Dryer
Dryer starts, heat up than the goes out
Faulty gas valve coils are the typical cause of this type of "cycling". These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves and permit the burner to light. If any gas valve coils are suspected of being faulty, it is recommended that both (all) be replaced at the same time. Hope this helped and best wishes.
Sep 02, 2009 | Dryers
Dryer heat shuts off
Hello, reading between the lines I'm going to assume you have a gas dryer. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Jul 24, 2009 | Whirlpool Dryers
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Whirlpool dryer with no heat
Is the igniter glowing yellow? Look inside the pilot access hole and see if it lights up. If it lights up then goes off, it may be the thermal fuse. Once this blows, it has to be replaced. There are pictures all over the internet on the location of this part.
Good luck.
Apr 16, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore 73952 Gas Dryer Logo
669 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
