Question about Amana ABB2224D Bottom Freezer Refrigerator
Your recent "solution"
And so what is the problem? the relay?
the compressor is not under warranty. the symptoms suggest compressor failure to me based on my review of online info and posted experiences of others...
  • 2,110 Answers
I think the relay might have problem...
Posted on Jan 03, 2009
Our model is a ED2PHEXMT .. bought 6/2003 Woke up in the nite to terrible plastic burning odor from the frig. Took it out of the house and removed the rear cover this AM ... the "relay"(?)...
Good day,
Sounds as if the relay burned up, or the compressor shorted out. Yu can remove the relay by unclipping the cover and pulling it off the compressor pins. The part should be available at any appliance parts house selling Whirlpool parts.
However, it could as well be a shorted compressor that burned the relay out. I would suggest you call a professional to service it. They have the equipment to test the compressor.
If the machine is under 5 years of age, leave it alone. The compressor is still under factory warranty.
Call your selling dealer for details on a warranty service call.
Nov 12, 2010 | Whirlpool ED2FHEXM Side by Side...
Noisy compressor
Is the compressor running when you hear this noise or is it noisy when it is trying to start. If the noise you are talking about is the click it may just have a bad relay on the compressor. If it is a loud humming noise when the compressor is trying to start then the compressor is locked up and needs to be replaced. Compressor comes with a 5 yr warranty and relay has a 1 yr warranty.
Nov 16, 2007 | Maytag MFD2560HES Bottom Freezer French...
Compact Refrigerator stop cooling, I am out of ideas.
Good day,
If you hear the compressor running, then the overload and relay are O.K. It can be one of three things.
1. Leak developed in system.
2. Restriction internal in the refrigerator sealed system.
3. Valves in compressor failed, which would not provide any pumping action for the refrigerant.
None of these items are practical repairs on a compact. But if it's under warranty (under 5 years old), check with the selling dealer for warranty claim.
P.S. Does not apply if coils were punctured.
Thank you for using FixYa
Jan 16, 2010 | GE GMR02BAN Compact Refrigerator
Whirlpool fridge incessant buzzing
The knocking noise when cuts off , is a compressor internal motor support spring , broken . This does not mean the compressor is bad , only noisy for the rest of the compressor life , but should be covered under the 5 yr warranty . The gurgling sound is the refrigerant being pumped thru the system . The buzzing could be from the compressor also . My suggestion , would be to call a factory warranty company , to see if they can replace the compressor under warranty .
Sep 07, 2009 | Refrigerators
Frig. is 5 years old - Not cooling - Buzzing clicking sound
Sounds like the compressor or start relay have went out.
For any recall info you would need to give the full model and serial to the Maytag.
Jul 27, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag french door fridge crapped out....again
buzzing sound comes from freezer fan or ice maker fan. They are located behind the freezer rear wall. These freezer fan cools the freezer and the refrigerator. The ice maker fan supply air to ice maker.
Jul 22, 2009 | Maytag MFD2560HES Bottom Freezer French...
Condensor fan runs. Compressor does not run and is warm to touch
Your start relay may have failed. It is an inexpensive part to replace. Using an extension cord will cause voltage drop contribution to the problem, if you have an extension cord in the line, elliminate it and plug the box directly into an outlet. If none of these suggestions apply, then the compressor has failed. replacement of the compressor can rival the cost of a new refrigerator unless the one you have is still under a warranty. FYI, compressor warranties can vary but are typically for 5 years.
Jul 11, 2009 | Amana Refrigerators
Refrigerator doesn't cool/freeze - clicking, cyclying noise repeates, but doesn't cool
We had the same thing happen a little while back. The compressor went out and had to be replaced (it was under warranty, but the labor wasn't covered)
May 17, 2009 | Maytag MFD2560HES Bottom Freezer French...
My Frigidaire #LSR7333PQ has had two compressor failures in 3 yrs
Compressors fail due to:
bad capacitors.
bad start relay.
low voltage.
refrigerant leaks.
refrigerant restrictions.
bad fan motor.
to name a few problems.
You should be under a 5 year seealed system prts and labor warranty.
Call him back out.
Mar 09, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire refrigerator
check the overload, take it loose and inspect it for a burnt spot shake it if it rattles replace the relay
you either have a relay bad or a stuck compressor
the compressor has a 5 year warranty on the part, the relay 1
so if you relpace the relay and it still doesnt run the compressor, call for serviece under warranty
Apr 27, 2008 | Frigidaire FRS26R4A Side by Side...
Amana ABB2224D Bottom Freezer Refrigerator Logo
156 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
