Question about Konica Minolta magicolor 2400 Laser Printer
Konika minolta 2400 color laser printer : Paper jammed and stuck
I have a piece of paper stuck in the area just below the yellow "Caution High Temperature" strip area.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
Konica Minolta 2400w paper jam at top back side. Several small pieces stuck and I can't reach them. Is there a way to disasemble?
yes there is a way, but if you do it yourself there are more chances that you will break it.so dont try it yourself.call concerning technical service rep.
Jun 10, 2010 | Konica Minolta magicolor 2400 Laser...
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
The printer jams often and often makes beautiful fans out of the paper you can contact me at yak1racs@yahoo.com
You probably have a piece of paper from a previous jam stuck in the printer. If it is making beautiful fans, then it is probably in the fuser module. (At least in my experience.)
I'm not sure about the minolta, but most printers have color coded levers inside that you need to open to check for paper jams. In HP's they are green.
Jul 16, 2009 | Minolta magicolor 2300W Laser Printer
Paper jam but I can't get to the pieces and no way to by looking at the book.. many days, no success
Well, you have to carefully dismantle it and try to take out the jammed paper.
Then, my advice to you is that you should be atention to humidity on the paper.
Keep your paper ina a dry place to avoid jamming.
Jun 29, 2009 | Konica Minolta magicolor 2400 Laser...
I have a konica-minolta magicolor 2400 which is printing a line down the right side. I changed the developer drummer, but it did not solve the problem.
If the line is white (no toner is added in that area) check the laser head glass which is located right below the drum. Remove the drum and you should see it below a narrow strip of glass. Just be sure to be clean, with no dirt, toner or pieces of paper on it.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Jun 17, 2009 | Konica Minolta magicolor 2400 Laser...
Paper got stuck in Konica Milolta magicolor 2400w
I had the same problem and this worked, although it is not the answer to your question:
Take a standard manila file folder and cut it to the basic shape of a standard piece of paper. When you lift the top cover on the under side you will see a diagram on how to pull the paper out in the case of a paper jam. Feed you file folder up from the bottom and you will ~ with a little work, more than likely be able to clear the jam.
Feb 20, 2009 | Konica Minolta magicolor 2400 Laser...
VERTICAL LINES ON KONIKA 2400
Oct 22, 2008 | Konica Minolta magicolor 2400 Laser...
Borderless printing
I don't think there is because it has to have some space to grip the paper through the drum and the fuser. Usually ink jets can do it but its tough to do on laser units.
Jun 19, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400 Error
remove the toner and see is there any peic of paper as awell as the drum also check
Sep 26, 2007 | Konica Minolta magicolor 2480 All-In-One...
Konica Minolta magicolor 2400 Laser Printer Logo
100 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
