Question about Hotpoint Refrigerators
Hotpoint rla34 - which number is the coldest setting?
My fridge is at setting number 3 but seems warm inside. Is number 1 or 5 the coldest setting?
docjohn174
  • 943 Answers
SOURCE: Beko LF320 temperature dial numbered 1 to 10 which way is coldest?
hi. thanks for the question i would try # 3 and let settle for 24 hrs .this should lower to above freezing .the appliance doc
Posted on Oct 01, 2008
  • 80 Answers
SOURCE: thermostat setting on frigidaire bar fridge 1 - 10
10 is the coldest. Hope this helps you:) I keep mine at 6 and its great.
Posted on Mar 16, 2009
localwonder
  • 6784 Answers
SOURCE: thermostat
HI, your intuitions are correct. this is defiantly a thermostat issue here. replacing this defective thermostat will fix this abnormal issue you are having with your unit.
When a unit of this nature cannot control the Coldness level, it is always due to a defective thermostat.
Posted on Jul 08, 2009
housejess
  • 317 Answers
SOURCE: which is the coldest setting for a fridge?
7 is coldest
Posted on Nov 07, 2009
Testimonial: "Boyso that was prompt! Thanks "
dmftrucker
  • 1922 Answers
SOURCE: the temperature gage is a wheel on the right hand
1 is warmest-7 is coldest
Posted on Dec 25, 2009
Testimonial: "fabulous thanks"
My hotpoint fridge RLA34 isnt keep my food cold
you'll cooling coils may be dirty thermostat may be going bad or it might be just a setting worse case a coolant leak requireing a repairman
Jul 30, 2012 | Hotpoint Refrigerators
What setting is the coldest on refrigerator? it goes 1-6
#6 is the coolest on the fridge, with the #1 being least coldest to #6 being the coldest setting.
Apr 04, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Freezer cold, not fridge
24 hours It should be good Do check temp settings.
Aug 05, 2009 | Candy CPCA240FFK Bottom Freezer...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Fridge dont get cold.
If the compressor is running then it could be one of the following:
The compressor isn't pumping properly. The thermosat has failed. It has lost refrigerant or there is a blockage.
Not alot of help I know but without seeing the fridge it's hard to say.
Feb 22, 2009 | Refrigerators
Temp control
Most refrigerator settings are in numbers like yours, the higher number will be colder setting.
Dec 20, 2008 | Candy CPCA240FFK Bottom Freezer...
Which way do you turn the temp. knob
loper the number on the thermostat dial, warmer the fridge. higher the number, colder the fridge. normal setting is about "3"
Apr 19, 2007 | Magic Chef MCBR170 Compact Refrigerator
Refrigerators Logo
27 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
