Question about Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000
Replace coleman generator fuel shut off valve
rtpflh
  • 546 Answers
SOURCE: My Coleman Generator Model 19G412 has a fuel
explore the possibility of removing & replacing the 'petcock'[fuel valve] in the tank.drain tank,remove gas line,unscrew petcock retaining nut at tank & replace.
Posted on Oct 12, 2009
Testimonial: "I did exactly what you suggested and it worked great. I am back in business with my generator just in time for more winter storms.!!"
sal_kh_sab
  • 98 Answers
SOURCE: Need to replace fuel shut-off valve
well..the whole valve has a place where u can place a 12 or 13 size spanner...and then just twist it..
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Posted on Oct 16, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Colman Powermate Generator will not stay running
This overflow can be caused by:
1. The float sticking
2. Gas inside of the float air chambers
3. The needle and seat have debris in them or a r damaged.
It is not a difficult fix but it does mandate removal of the carburetor float bowl.
You could probably do this yourself. It is much easier if you place the generator on a high work area so you can see the float and needle once you have the float bowl removed. Just make sure you do not drop the float assy so far that the needle comes out of the seat unless you have to remove the hinge pin SCREW for the float to clear the debris near the needles' pointed rubber head.
Thanks for using FixYa
Kelly
Posted on Mar 22, 2010
SOURCE: I have a Coleman Powermate
I installed a inline shut off valve and filter and it works fine and is cheap.
Posted on Jul 10, 2011
H2_Brad
  • 425 Answers
SOURCE: Where do you buy the
Take the old valve, called a petcock, to a local lawn mower repair shop and they should be able to help you.
Posted on Jul 16, 2011
Where is the fuel shut off valve
Powermate generators usually have a shutoff mounted to the bottom of the fuel tank. There is a knob at the bottom of the connector where the hose is attached to the fuel tank. Screwing it in (clockwise) shuts off the fuel.
Aug 30, 2012 | Coleman Powermate Portable Generator...
Generator is leaking gasoline out through the carburator when not running. Also, fuel shutoff valve at bottom of gas tank will not shut off completely. What are probable causes and price to fix ??
Most often fuel leaking out the carb is caused by a needle and seat problem in the carburetor / the float level shaft screw may have come loose due to the vibration of the engine ,this will cause a leak issue with the needle and seat as well. To complete the repair the carb will have to be removed and cleaned. Replace the needle and seat if necessary an then replace the carb.
May 30, 2011 | Coleman Powermate Powermate 5000W...
Where is the fuel shut off valve on a coleman powermate 2500
follow fuel line from fuel tank to the carb if you dont find it it probably does not have one
Sep 04, 2010 | Coleman Powermate Proforce 2500 Generator
Coleman sport 1850...when turned on .fuel runs into and right out of the carb until line closed. generator not used for two months but fuel was tunred off and unit allowed to run until it ran out of fuel. ...
When you drained the carb chamber by working with closed line, the floater in the carb chamber has fallen down. After two months later you let the fuel in again, the floater remain in down position and could not shut the input needle valve.
You may try to knock sharply (but not very hard) the carb cover when full, before opening carb cover in order to check the floater and valve.
Aug 04, 2010 | Coleman Sport 1850 Generator
Can't start my coleman 1850 generator
Need more info,
Does it turn over??
Does it have spark??
Does it have fresh petrol??
Feb 25, 2010 | Coleman Sport 1850 Generator
My Coleman Generator Model 19G412 has a fuel shut-off screw/valve. It was in the off position. I needed to use the generator, but when I tried to turn the screw/valve to the on position, it would not turn....
Oct 12, 2009 | Coleman Powermate Powermate 5000W...
Fuel leaks from around the valve at the 5 gal plastic fuel tank
you twist the whole valve after disconnecting the hose...
get a new one and put it instead...
if u have any further questions let me know:
Jun 29, 2009 | Coleman Powermate Powermate 5000W...
Need to replace fuel shut-off valve on Coleman Powermate Generator PMO525202. It has a 5 gallon plastic tank. How do I remove the original valve(without breaking something)? Thanks,
Jun 03, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000 Logo
98 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
