Question about Maytag Bravos Series MVWB750WB Washer
How to remove agitator and drum on a maytag bravos mvwb750wq
2 Suggested Answers
dcramer531
  • 1654 Answers
SOURCE: maytag bravo mvwb750wq 28"
Have you tested the lid switch, if it is not making the washer will not spin. try using a pen or small bladed screwdriver to depress on the switch to see if you hear it clicking, although sometimes it wont work even if it clicks when they go bad. The washer should work as normal till it gets to the spin cycle, then without the lid switch working it won't go any furthur. You can try jumping across the leads to see if this gets it to spin and this will tell you if the switch is bad or not.
Posted on Mar 08, 2011
How do I get to the drum belt
Type Maytag Bravos 7.0 dryer drum belt into YouTube and see if the video comes up, thanks!
Sep 08, 2014 | Maytag Bravos MED6400TB 7.0 Cu. Ft....
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Have a Maytag Bravos XL MEDB9504WO that works, but very noisy. Bought a pulley that sits on top of
Sounds like you need new drum rollers, so you need to disassemble the front of the machine and remove drum replace all drum rollers and idler pulley also check blower for damage.
Jul 31, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
A penny slid under the agitator how do I remove the agitator?
takes a special nut to remove. why not just wash some thing else, it will come out
Jun 13, 2011 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravo mvwb750wq 28"
Mar 08, 2011 | Maytag Washing Machines
I have a 2 y/o Maytag Bravos MVWB700VQ0 top-loading washer that is suddenly making noise like there's either a) a chain loose in the drum of the machine, or b) a coin or other metal object is bouncing...
it is probably money in the pump. I have had my washer for two years now and an on the second pump. I had to call a serviceman to take the pump loose and dump out the change. It had 81 cents the first time and 26 cents the second. I need to call him again but I think I am going to try to do it myself. $85 a service call is just ridiculous when I know what the problem is.
Oct 12, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Clothes stuck inbetween basket on Maytag Bravos washer
This is for several brands ... not just the Bravos.
Based on your description, it looked like you needed to take the center agitator out first .... to then access the inner basket bolts ... remove the inner basket to then get to where the clothes are ... not a real easy task
capture-ce5c5tqeeiqfekdpzmvievq3-1-0_0.png Good luck on your troubleshooting
Jan 25, 2018 | Maytag Bravos 3.8 Cu. Ft. Washer
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
WE HAVE A BRAVOS WASHER AND MY WIFE DROPPED A PENNY IN THE DRUM AND FELL UNDER THE AGITATOR. DOES IT NEED TO BE REMOVED BEFORE USING IT AGAIN. AND COULD I REMOVE IT IF IT NEEDS BE.
Hi mate I would advise you not to use the machine again as you can create more problems if you unscrew the screw on top of the agitator and lift off the agitator you be able to see the penny and take it out or if you cant see it then it is gone down into the pump you who than have to take out the pump undo the hose turn the pump over to one side and it should fall out
Jul 18, 2008 | Maytag Washing Machines
Maytag Bravos Series MVWB750WB Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
