Question about Starbucks Barista Burr Grinder
Starbucks Barista EL-60 Burr Grinder manual - Starbucks Barista Burr Grinder
4 Suggested Answers
  • 4088 Answers
SOURCE: starbucks barista burr grinder: the motor runs but
The drive mechanism from the motor to the burrs has failed in some way. It is necessary to disassemble the machine down to the basic components to determine the fault. Good luck!
Posted on Apr 06, 2010
Sagar Tech
  • 107 Answers
SOURCE: I took my Starbucks Barista
I think when you fix the front burr then you need to loose the middle screw. Then it will fix easily.
But don't run it right away.gently tighten the screw and tight until you feel some tightness .Then start the grinder and tighten or loose it according to your grinding specification
thanks
please rate me
Posted on Aug 28, 2011
mc1bean
  • 3053 Answers
SOURCE: After cleaning my Starbucks Barista
Here is a link for you to copy and paste in your browser and this will tell you everything and then some about your Burr Grinder, and how to clean it and put back together.
http://www.starbucks.com/assets/starbucks-barista-burr-grinder.pdf
I hope this helps you, Mike
Posted on Sep 14, 2011
Need replacement part for Starbucks Barista Blade Grinder! Please help? Went to grind as I usually do but there is apparently a plastic circular part under the blades (I imagine that keeps the blades in...
your best bet is probably to search ebay for a dead one you can strip, cheaper grinders tend not to be supported with parts, personally id recommended throwing it away and getting a better grinder, blade grinders do not give a consistent grind, they are just about acceptable for grinding for a french press but anything else youll be far better off with a burr grinder
May 10, 2011 | Starbucks Barista® Blade Grinder
I took my Starbucks Barista Conical Burr Grinder apart to clean it, and now I cannot seem to get the top burr back on. This is an old model, purchased in 2000, and has been running great. I used to manage...
thanks
please rate me
Apr 02, 2011 | Starbucks Barista Burr Grinder
It says to "lift the
BURRS are the metal parts that grinds the coffee. There are 2 BURRS in the grinders, The upper burr is normally the one you adjust (Fine or coarse) and the lower or closer to the motor is the one turning during the grinding process.
Jan 25, 2011 | Starbucks Barista Burr Grinder
How to clean burrs
Easiest way run a tablespoon of rice through the grinder.
Apr 25, 2010 | Starbucks Barista Burr Grinder
Starbucks barista burr grinder: the motor runs but the beans won't grind
Apr 06, 2010 | Starbucks Barista Burr Grinder
My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Jun 07, 2009 | Starbucks Barista Burr Grinder
Does not grind
Sorry no answer ...i have similar problem described
Mine... sounds like it is working but nothing grinds. Any suggestion no this issue
May 14, 2008 | Starbucks Barista Burr Grinder
Coffee Makers & Espresso Machines Logo
412 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
