Question about Acer TravelMate 2300 Notebook
No audio volumn
When turning on laptop boots up with no volumn,have been into control panel then into sounds and devices and volumn section is greyed out and set to zero.
  • Lee Laws May 11, 2010
    Hi andrew,
    Does your sound hardware show up in the device manager? If so you might want to reinstall the drivers
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Try
http://www.realtek.com.tw/
Posted on Jan 09, 2009
How to turn the volumn control on on the acer laptop. tHE VOLUMN control is on off and it won't let me turn it on. My acer laptop uses windows7 '
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Mar 31, 2011 | Acer Computers & Internet
No sound at all
1) Go to: Start > Settings > Control Panel > Sounds, Speech, and Audio Devices > Audio tab 2) Check what's under "Sound playback: Default device" and "Sound recording: Default device". It these fields are grey and non-clickable, then most probably the audio card driver is missing or less probably the audio card itself is broken. 3A) If you have an original CD of your computer, motherboard, or audio card, insert the CD and install the driver from it. 3B) Or alternatively insert the CD and go to: Start > Settings > Control Panel > Performance and Maintenance > System > Hardware > Device Manager, find any unidentified device in the list, or expand the "Sound, video and game controllers" branch, identify the Audio card > Right click > Update driver... > Install the software automatically > Next 3C) Or alternatively download and install a free driver updater software, e.g. http://www.innovative-sol.com/drivermax/index.htm - let it scan and update all your missing drivers. P.S. These steps mentioned above are for Windows XP, but will be quite similar on other Windows versions, too.
If you tell me your laptop's model name, I could find its website where you can download audio drivers. For example if you have HP laptop, go to www.hp.com and enter your laptop's model number and look for driver downloads offered.
Mar 07, 2011 | Computers & Internet
I have a problem with sound card alc888 does not configure with dg31pr
The Intel High Definition Audio with support for 5.1 surround sound and is designed for Windows Vista premium desktop and laptop systems only.
Determine Your Audio Driver Version If you have Windows 7*:
  1. Click Start > right-click Computer > Manage.
  2. Select Device Manager.
  3. Expand the Sound, video and game controllers section.
  4. Right-click your audio device and select Properties.
  5. Go to the Driver tab to view the current driver version.
If you have Windows Vista*:
  1. Click Start > Settings > Control Panel > System > Device Manager.
  2. Expand the Sound, video and game controllers section.
  3. Right-click your audio device and select Properties.
  4. Go to the Driver tab to view the current driver version.
If you have Windows* XP:
  1. Click Start > Control Panel > Performance and Maintenance > System.
  2. Go to the Hardware tab and click Device Manager.
Nov 24, 2010 | Intel DG31PR Motherboard
No sound at all
Go into sound properties in "Control panel" and click on "sounds and audio devices" or similar.
Click on "audio" and make sure all boxes are normal not greyed out. If greyed out you need to re-install driver. If all there, check volume control is set correctly.
Dec 21, 2009 | Dell Inspiron 8600 Notebook
No sound
Try this:
Click Start, select Run, type "services.msc" without the quotes and press Ok. Services window will open up. In that window, select the Windows Audio Service and the status and startup type of the same. In case the startup type is disabled, double click on it and select the startup type as Automatic. After that right click on this service and click Start. In case the Start is greyed out, click on Restart. Now check for the sound.
Jul 07, 2009 | Compaq Keyboard
No sound or voice from the pc?
Have you installed the audio driver? If you have installed an audio driver, it most likely an incorrect one. To check if you have installed a correct audio driver. Go to the Control Panel - click on Sounds and Audio Devices - click on the Sounds tab - click on any of the Program events and click the play button. If you hear a sound from the speakers the audio driver is correctly installed. Also connect a headphone to the laptop and repeat this test.
If you don't hear any sounds and the play button is greyed out, it means the correct version of the audio driver wasn't installed.
You can check if this is true - go to Control Panel - System - Hardware tab - Device Manager and look for any devices that have a yellow ? against the device. This indicates a device driver is required to make this device work.
You need to download the correct device driver for your model laptop, and it must be a XP or Vista version that matches the Windows version that is installed on your laptop.
Jun 03, 2009 | Compaq Presario Notebook
Satellite 5205-s505 speakers aren't working, headphones OK.
Start- Control panel- Sounds and Audio Devices- In the device volume section click Advanced- Click Advanced again and check if In the other controls section 1 PC Spk mute is checked if so uncheck it If that does not work please let me know so I can help you further
Dec 09, 2008 | Toshiba Satellite 5205-S503 Notebook
Web Cam
1. Go to Start\Settings\Control Panel\Sounds and Audio Devices 2. Click on the Audio Tab. 3. In the Sound Recording section section, verify that your webcam is selected as the default device. 4. Click on the Volumne button, and verify that the Microphone slider is moved all the way to the top, and that the checkbox is checked.
Jun 02, 2007 | Logitech QuickCam Pro 5000 Webcam
Computers & Internet Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
