Question about Canon PowerShot A85 Digital Camera
Camera won't turn on
I have had my digital camera for a little over a year, and not too long ago it was working fine when the batteries died (at least I think that's what happened). I recharged the batteries and put them back in. It didn't turn on. I tried about 3 different sets of batteries, all of them brand new, and the camera still won't turn on. The camera hasn't been dropped, exposed to extreme temperatures, or anything like that. When it turned off, the lens stayed sticking out and it won't even turn on long enough to go back in. It won't turn on when I connect it to the computer, it just will not turn on. What could the problem be and what can I do to fix it?
  • jsiowa Oct 26, 2008
    I have a similar problem - I took a picture, camera worked just fine, turned it off, came inside and hooked up to computer, tried to turn camera on and it simply won't turn on. Replaced batteries with new, still won't turn on. Have checked memory card, although that was fine when I took the picture, so I'm mystified.
  • Anonymous Nov 08, 2008
    Same as the others. My Canon PowerShot A85 camera will not power up. I checked the batteries, and also used new batteries, still didn't work.
  • 59 Answers
Also, be sure to check where the memory card goes in. If the pins are bent, it could be shorting something out!
Posted on Jun 08, 2007
  • Steve Bryant Jun 08, 2007
    Check the pins where the memory card goes in. A bent pin can short things out and prevent it from working properly
    Genius:
  • 2,985 Answers
This appears to be a common contact fault Check the battery compartment and the battery cap. Try a piece of foil across the batter yop and close the lid see if that makes any difference. If not Contac the Canong Website- tech support Also take a look at http://www.fixya.com/support/p293997-canon_powershot_a85_digital_camera/solutions
Posted on May 18, 2007
SOURCE:
Pentax k2000 won't save time and date
In most modern cameras is a little rechargeable battery, that keeps the clock ticking. If your camera was a long time without power, perhaps this battery has died. I would buy a new set NiMH rechargeable or recyclo batteries, because they have a bit less capacity, but can hold power for as long as a year. Then charge them and leave the rechargeable batteries in your camera. Keep your fingers crossed, perhaps the little clock battery will be revived?
Feb 15, 2014 | Pentax Cameras
My Kodak EasyShare C180 10.2MP Digital Camera is less than a year old and suddenly won't turn on. I thought the batteries were dead so I replaced them...twice...and tried changing the direction around...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jul 06, 2011 | Kodak EasyShare C180 Digital Camera
My camera will not charge. It was purchased just short of a year ago, so here is no reason for the battery to be broken. It will not charge at all when the memory card is inserted and when it is, the...
Hi, It almost sounds like the battery won't hold a charge anymore which means you need a new battery. Since the camera isn't quite a year old yet I'd suggest contacting Nikon and seeing if they'll do anything for you before you buy a new battery.
May 12, 2011 | Nikon Coolpix S4000 Digital Camera
The battery for my camera does not charge when I put it in the charger. I have had the camera and charger for about a year without any problems until now. When I put the battery in the charger, the green...
Assuming the camera is working fine:
Probably the battery, but can't be certain without testing. They do wear out from use. New battery packs sell for a little over 20 bucks - a two pack for for $35 - you can likely fine them cheaper at a battery specialty store online. Do a google search on "battery NP-40" You could also search for a compatible charger, just in case :)
Jan 04, 2011 | HP PB360t Digital Camera
My Pentax optio E40 8.1 MP batteries keep dying afer 20 pics???
Try cleaning the contacts by breathing and rubbing, if this doesn't work, put a LITTLE BIT of alcahol on a cotton swab, and clean.
Jul 03, 2009 | Pentax Optio E40 Digital Camera
My camera won't turn on
Your battery is defective. Call tech support and tell them you have the EXZ75 but DO NOT tell them that you have had it for over 2 years and they will replace it for you for free. :)
Mar 17, 2009 | Casio Exilim EX-Z4U Digital Camera
LCD NOT WORKING
Your batteries need to be replaced. Need new batteries.
Oct 24, 2008 | Canon PowerShot A85 Digital Camera
Camera won't retrack
August - this sounds like the same problem I had with my Finepix510. Turns out the new unopened package of batteries I put in weren't fresh enough and weren't working. When I got truly fresh batteries, everything started working just fine again.
Hope that turns out to be true for you.
Dec 28, 2007 | Fuji FinePix E510 Digital Camera
Canon PowerShot A85 Digital Camera Logo
143 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
