Question about Yamaha DVD-S657 DVD Player
We have a Yamaha DVD S657 (actually we have three).  We were gone for three months and when we returned two out of the three will not open the drawer.  One of these has only been used about 5 times.  They were purchased in 10/06.  I tried the one thing I found on Yamaha's FAQ to press the power button on the remote at the same time pressing the stop button on the unit but that didn't work.  Isn't it weird that they both failed at the same time with the same thing?  Is there something else to be done?  We live kind out out in the "boonies" so it would be great if we can fix this ourselves.  Thanks in advance for any help!
5 Suggested Answers
  • 4402 Answers
SOURCE: Change Regions zones
Posted on Jan 04, 2008
SOURCE: dvd player died
Did you check the fuse in the power supply? You have to open the box and its very easy to get to. DS
Posted on Mar 05, 2008
  • 236 Answers
SOURCE: Tray opens but won't close or closes but doesnt play
deferctive laser lense already. try to replace if more economical than buying new unit
Posted on Mar 31, 2008
  • 12 Answers
Try this: With "No Disc" on display. Press the following buttons (slowly) on the remote.
PLAY, 2 7 4 2 2 2 2 2 2 0 0 5 2 5 5 PLAY
This is the De-Zone for a simular aged Yamaha Player.
Posted on Dec 17, 2008
I have nt4.0 when i connect my yamaha crw8424..the system recognize de number.. but no sync. then i cant see anything
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Mar 20, 2011 | Yamaha CRW 8424 CD-RW Burner
I have a DVD and a HD cable box going through my Yamaha RX-2400. Things worked great for past 6 months but recently started getting flickering picture and eventually picture was gone. TV says it is...
I'd investigate the intervening video-carrying cables.
Consider whether you actually NEED to route video through the receiver in the first place. Is all that extra cable and 2 extra interconnections actually doing any good? Apparently not.
In my rig, I run high-end video only to my TV and high-end audio only to my receiver. No problemos.
Feb 12, 2011 | Yamaha RX-V2400 Receiver
Dynex dvd player displays a white screen when fully open. When the dvd play is almost folded shut, the proper Dynex blue screen appears. Is there a fix for this or is it garbage? It's only 3 months old!
If its only three months old, take it back to retailer and they can either return to authorised repair agent for repairs or replace for you, just make sure that go to the retailer with the receipt and warranty information. I hope this helps.
Nov 26, 2009 | Televison & Video
Yamaha S661 Player wont play multi region
This one is for S530, S540, S550, S557, S560, S600, S657. It's worth a try. Tell me if it works.
  1. Open the disc tray
  2. Press 9, 9, 9, 9, 0
  3. Press ENTER
  4. Close the disc tray
Apr 13, 2009 | Yamaha DVD-S661 HDMI DVD Player
Freeze then red ring of death twice
it is definately a possibility that where you keep your Xbox is the problem. ive actually gone through 3 so far (thank god for the xbox return service)  on the latest one i moved it to on top of a speaker away from anything that gives off heat when in use (like your dvd player) and its outlived the other 2. good luck!
Sep 05, 2008 | Microsoft Xbox 360 Console
Dec 16, 2007 | Yamaha DVR-S120 DVD Player
DVD Player
heh... I wouldn't recommend the crowbar. Their is a belt inside the drive underneath the actual reader, it's broken, happens alot. As to actually fixing that issue, you would have to open up the case and take it apart, can be difficult on some drives. I don't know where you could get a replacement belt either. I had to turn my samsung into a manual dvd player (I have to pop off the top, pick up the drive and slide over a pin to open it.) I wouldn't actually recomend that, I just didn't feel like paying to have it fixed. I couldn't find a belt anywhere. which left me with the option of going to a repair center. Probably your only option as well... Unless of course you do like the idea of a frankenstein dvd player. Good Luck
Jun 19, 2007 | Yamaha DVR-S200 DVD Player
Yamaha DVD-S657 DVD Player Logo
32 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
