Question about DeLonghi DH100P Dehumidifier
Delonghi dh400p leaking - DeLonghi DH100P Dehumidifier
4 Suggested Answers
  • 159 Answers
SOURCE: Dehumidier Delonghi DH400P not removing any water from the air
Only thing I can tell you to do is to make sure that the evaporator in the back is ice and cold. If the evaporator is not cold the unit will never remove moisture from the air. And if that is the case you have a sealed system problem. The unit may have a leak so there is no gas in it. The compressor may not be working or the humidstat my not be working properly. So check those thigs out or if its under warrenty call for service.
Posted on Jul 12, 2007
SOURCE: Delonghi DH400p dehumidifier running but not
Hey, I had the same thing with mine.
First, try cleaning out your filter if you haven't already. It gets angry if it can't get any air.
If not, I don't know how brave you are, but I ripped mine apart to fix the problem. I took off the panel with the filter (5 screws) and you can see a collection tray with another little collection gutter under that. Both of mine were filled with junk, mostly dust that had gotten wet to make this awesome disgusting sludge. If you can get at it from there, try to clean the sludge out of the collection tray and the little gutter. I ended up taking my whole unit apart so I can get the collection tray out (dumb design, you have to take apart the whole dang casing to get at two screws that hold the collection tray in).
Posted on May 23, 2010
  • 104 Answers
SOURCE: Error code E3 on delonghi dehumidifier DH400P
Be Safe or don't do it....
On the side with the lint screen, remove the five screws holding the top panel in place. The sensor that needs to be checked in mounted on the radiator fins. Remove the sensor and 4 pin connector. With a pin, remove the loose fitting housing the "sensor"...a circuit board that "shorts" with condensation...check corrosion and look for component damage on the oft chance the circuit board was damaged by some inappropriate poking or mechanical failure. Reassemble and replace sensor...
For a short life span...or out of warranty and only at your risk (IF have significant other or kids or pets or human DNA... don't do this...) .. guide wire through screen notch and attach to outer screen. Build fortress around exposed sensor and talk to insurance agent for a special rider...seriously be careful.
Did you? Clean screen and GENTLY clean fins of lint, etc....(vacuum's brush head should do the trick...)
Taking all appropriate safety precautions.
Here's the 100,000 (yen) tip....with humidifier unplugged, hold down the power button (green button in lower center) and plug in the appliance.
Watch the LCD screen as it conducts a self test...and wha...lah!.
Should have a working humidifier!
(your welcome).
no really..."de nada". :"don't touch your moustache" "Doye toche moche"(?), "prego".
Posted on Mar 27, 2011
What is the part/how to find replacement discharge tube for DH400P? I lost the original hose because, initially, I was able to just drain into floor drain. Now, new location, I need to use the pump feature...
Try explaining what you need to an appliance parts supplier or find a current model DeLonghi dehumidifier and identify to a salesperson what you need.
Jun 12, 2014 | Dehumidifiers
Delonghi DH400p dehumidifier running but not collecting any water ? Humidity is 68 set to 50???
May 14, 2010 | DeLonghi Dehumidifiers
My delonghi dec180e dehumidifier filter is jammed in the machine. it's also now leaking - how can I fix?
you can download the manual here: www.delonghi.co.uk/pdf_files/DEC180E.pdf
thanks
Paddy
Feb 02, 2010 | DeLonghi Dehumidifiers
DeLonghi dehumidifier hose by drain tray leaking
I think that I am having the same problem, but I'm not sure that this tube needs to be plugging into anything. However, my humidifier seems to be draining out of this tube rather than from the tray into the bucket.
Jul 14, 2009 | DeLonghi Dehumidifiers
My 3-month old Delonghi 50 dehumidifier is leaking
Did you find the solution to your delonghi 50 pint issue? We have similar problem and No Manual - we are looking for manual too, any thoughts on where to find that too, please?
Jul 06, 2009 | DeLonghi DE500P Dehumidifier
Delonghi dh400p dehumidifier error e1 with ice
was the filter dirty that will do it let it defrost and put it back on
May 17, 2009 | DeLonghi De'Longhi Energy Star174;...
(your welcome).
Apr 10, 2009 | DeLonghi DH40P Dehumidifier
Delonghi DH400P Discharge Hose
I have the same problem on ocassion.
I just remove and reseat again , making sure the front of the tank is flush with the unit. sometimes a little more push in does the trick
Aug 11, 2008 | DeLonghi DE400P Dehumidifier
DH400P
I had a similar problem with the pump not working and the water flowing into the main drainage bucket instead. I had to disassemble the housing...not an easy project to reassemble...and found that the pump has its own smaller drainage tank with a float device, a pump pre-filter, the actual pump, then of course, more drainage tubes. The entire pump drainage system of components needed cleaned of accumulated, mucoid, slime! I cleaned the channel in which water flows into the pump's tank...located on the screen filter side of the dehumidifier. Then I moved to the other side of the dehumidifier and cleaned-out the entire pump drainage tank. Note that the pump's drainage tank only empties about 1/2 inch of water each time the pump activates. Thus, there is always alot of water in the pump's drainage tank. Thus, alot of time for slime to accumulate. Next, I cleaned off the float mechanism. I then cleaned-out the pump's pre-filter. Cleaning out the pump's pre-filter was paramount to the pump functioning properly and quietly! I checked that my pump was properly installed and NOT rubbing against its mounting so that it operated quietly. I added fresh water to the pump's tank several times to insure that the pump was working properly and that all slime was eliminated. Finally, I reassembled the housing...not an easy task! My pump now functions like new. All this work had to be done to insure proper function of the dehumidifier's pump system. My dehumidifier is only 11 months old. It is still covered by the one year warranty, but it is too expensive to ship the entire unit, as Delonghi requires you to do at your expense for them to fix it under warranty. You can be assured that I will check for future slime build-up to keep my dehumidifier functioning properly. The dehumidifier works great, it's just that it's high maintenance.
Jun 15, 2008 | DeLonghi DE400P Dehumidifier
Jul 11, 2007 | DeLonghi DE400P Dehumidifier
DeLonghi DH100P Dehumidifier Logo
42 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
