Question about Ryobi Saws
How to fix the rusty/locked blade release lever on Ryobi recip. saw
The blade release lever is rusty or locked for some reason and I can not install the new blade. Please help. Model #RJ162V
  • 5 Answers
SOURCE: Blade falls out.
the lever for the lock has a indentation in it to lock the blade in place (at 90 or 180 degrees try both) make sure it drops into same in blade. not all brand blades will fit even with the word universal! good luck
Posted on May 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: dewalt recip saw 307m no longer holds saw blade. I
I would go to Dewaltservicenet.com and type in your model number on the page and it should bring up a schematic that you can download and see where the part goes. Let me know if you have trouble finding it, if so I need the exact model number.
Posted on Jul 20, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a Milwaukee sawzall 6509-22 with a quick
K you used the saw after inserting blade?? If so couple ideas, hold collar open and put saw blade in a vise and try pulling back on saw, or you can remove the quik lok cam and release it that way, its not that hard, but I would try vise first. Let me know
Posted on Jul 29, 2009
SOURCE: dewalt recipr. saw keyless chuck tab used to
We had to send our saw to repair center to install new lever. Fortunately, still under warranty.
Posted on Aug 10, 2009
  • 57 Answers
SOURCE: blade stuck in reciprocating saw
The pin is probably stuck in the blade. This happens from time to time after they get dirty. Take some WD-40 or some other type of penetrating oil and spray a little in the blade holder while working the release lever. It will probably free right up.
Posted on Apr 24, 2010
Remove blade from master force saws all
  • 1. Disconnect the saw from the power supply.
  • 2. Open the blade-clamp release lever.
  • 3. Insert the saw blade into the blade clamp as far as it will go, and release the blade-clamp release lever to lock the blade in position.
  • 4. To remove the blade, open the blade clamp release lever and pull the blade from the clamp
Blade cannot be removed Saw dust in the clamp slot
Clean the clamp slot with brush
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=masterforce+saws+manual
Dec 09, 2015 | Saws
HOW DO YOU put new boot back on ryobi reciprocating saw?
No. You spin it onto the tool clockwise. When you get far enough on, the lever will slip right into the slot.
I like to take my shoe off, and use my foot to hold the hand grip while sitting down. This allows me to use both hands to twist the rubber grip off/on.
Jun 24, 2015 | Ryobi Rj165v Reciprocating Saws
How do I install a blade
Your Ryobi saw may have a twist-type chuck. You twist it and hold it twisted open to insert the blade, then release it secure the blade.
Nov 17, 2014 | Ryobi Reciprocating Saw Rj160v
How can I fix a jammed Ryobi miter saw blade?
Probably go a piece of wood between black and safety cover. Unplug from power before checking
Apr 30, 2014 | Ryobi 18 Volts Cordless Miter Saw 18v P551
How to remove broken blade stub from cordless ryobi reciprocating saw
Try spraying the clamp assy with WD40 and then gently bang the front down against the work surface whilst holding open the clamp lever.
May 16, 2012 | Ryobi 18 V Cordless Reciprocating Saw
My lever to my Dewalt xrp reciprocating saw some how got stuck in the lock position and i have no idea how to remove the lever to fix it
Often when these recip saws get jammed around the blade or lever it is usually due to sawdust or grit that has worked it's way into the mechanism or else the mechanism has actually broken. After a full day of work I often have trouble getting blades removed.
First try spraying the whole mechanism with silicone lubricant and let it soak in. Try tapping as forcefully as you can around the mechanism without breaking anything. If the lever and mechanism isn't actually snapped off somewhere, this usually does the trick.
Dec 02, 2010 | Garden
JR3050T blade lock lever is stuck
Put a blade in it.
This will release the locked open feature.
Dec 30, 2009 | Makita JR3050T Recipro Saw 9 Amp
Blade falls out.
May 06, 2009 | Dewalt DC385B 18v. Cordless Bare...
Blade lock on Craftsman 10 amp recip
The guide foot comes completely out by wiggling and pulling a little harder than you would think. It is held in place by friction in addition to the two screws. Once the guide foot is removed, remove the front metal support piece by prying it out of the groove in the rubber boot. You can then access the pin and blade release lever. Make sure the return spring is in place on the rear side of the blade lock latch.
Apr 11, 2009 | Craftsman 8.0 amp Reciprocating Saw
Ryobi Circular Saw
unplug saw
new Ryobi have a spindle lock button, it is unobtrusive and you may miss it
739d802.gif If yours does not, secondhand etc, a screwdriver in the blade teeth between the upper and lower guards provides a locking bar enough to undo the arbor bolt
Jul 30, 2008 | Ryobi Multi-Volt Battery Charger
Saws Logo
69 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
