Question about GE 24 in. GSD6660GSS Built-in Dishwasher
Ge triton won't drain
Goes through the cycle just fine, but the water won't drain it just sits in the bottom of the washer
  • hangurhat Jan 06, 2009
    GE dishwasher, model #gsd4000j00bb, when it hits the draining point of cycle the motor just stops. Checked solenoid which registers 40 ohms(as I read it should). Lines all clear. Machine is less than two years old.
Well, I haven't heard from anyone from this site yet, but I did talk to Mike Anderson of Anderson Appliance Repair in Clinton, Ten. He told me how to test the solenoid (should read 40 ohms at 1X on a multi tester). Check that the float at the bottom left corner is working and finally test the wires going into the motor (my motor shut down the moment the machine hit the drain cycle). Sure enough, I get 110 volts throughout and 0 at the drain cycle. He says it needs a new timer. If you try to clean it you'll have little springs and things shooting out. Good luck. and Thanks to Mike Anderson (865-945-3808)
Posted on Jan 06, 2009
Dishwasher won't drain all the way
A dishwasher will never drain all the way. It is designed to hold water as to not let the pump run dry and keeps the seals preserved.
Jun 03, 2017 | GE Nautilus 24" Built-in Dishwasher
GE Triton Dishwasher timer may need adjustment ?
you have a clogged drain hose or a weak pump.  There are no adjustment on the timer it is what it is.
Apr 12, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE Triton dishwasher will not drain and after cycle.
Look at the timer to see if the contacts have finally worn off. The circuit board may have failed too.
Nov 09, 2017 | GE 24 in. GSD4320Z Built-in Dishwasher
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer keeps pausing
you may have something in your drain pump.
1) Remove the three screws in the bottom remove bottom panel.
2) Remove drain pump cover (have towels or pan to catch water that comes out)
3) Remove any debris from pump, check that the impeller is not damaged and can be moved freely.
4) reinstall drain pump cover and bottom panel
Let me know if it helps
Sep 07, 2008 | GE WBVH6240F Front Load Washer
GE Triton Dishwasher will not drain they water after it's cycle...thoughts?
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
The machine was in your home 3 years , and used for more than that by someone else! I can tell you by the model that its at least 10 years old!
appliances more than 9 years old cost you money to run and fix! Throw it out and do not put good money into bad!
The new ones no matter how inexpensive will wash better and cost you a hell of a lot less to operate. They are so much more energy efficient today that they pay for them selves in a couple of years! With a new machine watch your water and power bill go down!!!
Other wise you need hands on service!
if you got the money do it new!
Bless You!
Sep 02, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Triton XL
Try placing a packet in the bottom of the DW and then start a wash cycle ( use the energy efficient cycle that does not use the heater to dry the dishes..).. if it is not disolved at the end of the cycle then your water temp may not be hot enough..Hope that helps..
Aug 28, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Ge triton
Power outage was the culprit for me as well. Resetting the breaker fixed it immediately. YAY!!
Nov 17, 2007 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
212 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
