Question about Kitchen Ranges
Temperature decals have warm off of our Electrolux range (PLES389DCC). Can I replace then?
2 Suggested Answers
SOURCE: PLES389DCC Frigidaire Electric Range
I just replaced the top it is very easy if you know which screws to take out unplug the stove
LOTs of hidden screws so remember I only had 4 left overs.
First take the knobs off and the 4 black knobs below the real knob
Unscrew the black thing right under the knob this holds down the STEALESS steel cover for all your screws.
then start taking screws out of the fron the top sides and the screws along the oven door.
The screws near the top releases the glass and frame.
MARK COLOR CODE WITH MARKERS OR TAPE BUT DO IT BECAUSE you wont remember like me.
Wires unplug all of the connections that you see, P11 and P13 is where I had my problem they came off. the board eek
Be careful over lable I just exploded my stove when i put it all back together one wire came off I did not lable it.
239.00 for the board 289 for the glass
IF ANY WIRE COME OFF read the ciruit board Schematic
In still workng on my stove I cant believe it blew up the board.
KDH
Posted on Jul 25, 2010
I have a frigidaire ples389dcc as soon as i plug it in it give me a pf code
Good Morning Paul, thank you for your post!
Based off what you have described your Frigidaire range, PLES389DCC, is providing you with an error code of "PF" and "F1" as soon as you turn it on. An error code of "PF" stands for power failure this could be a possible problem with your control panel or power cord.
The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F1" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Apr 10, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
HOW DO YOU REMOVE YELLOW STAINS ON TOP PART OF OVEN DOOR THAT ARE THERE BECAUSE OF HIGH HEAT FROM CLEANING OVEN
Hey friend, thank you for your inquiry!
I understand that your Electrolux range has yellow stains on the top of the door. Typically you should just use warm water and mild soap to remove any stains on your range. If that does not help to correct the issue I would suggest a touch up paint that can by typically purchased through your manufacturer or replacement of the door. I hope this has been beneficial. -Matt
Oct 16, 2014 | Electrolux Frigidaire Oven Temperature...
Where is the reset button on my electrolux fridge?
Good Afternoon Friend, thank you for your post! I see the temperature in your Electrolux refrigerator is too warm and would like to know how to reset it. May I please have your model number? The serial tag, which lists your model number, is typically located inside the cabinet, on the right side wall. With this information I can better address the issue at hand. In the meantime, please double check the temperature control. If the temperature is set too warm, set control to a colder setting and allow 24 hours for temperature to stabilize. Thank you - Z.
Apr 22, 2014 | Electrolux Refrigerators
Electrolux oven f10 error code
Hello Mary, thank you for allowing me to assist you!
Typically error code F10 indicates your range has detected an issue with the runaway temperature (overheating). Let's try reprogramming your appliance by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn your range on. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Nov 20, 2013 | Electrolux E30DF74PS Dual Fuel (Electric...
Replace control panel
Trying to replace the glasstop on my Frigidaire PLES389DCC. I have followed the posted instructions. I have removed the 4 front screws as directed. I am still having difficulties removing the front control panel, are there some clips or snaps that free the panel? I do not want to break it since it still feels like something is holding it in place.
Nov 15, 2010 | Frigidaire PLES389D Electric Kitchen Range
On a Frigidaire PLES389DCC how do you replace the electronic controls. I mean how do you get to it?
1. remove burn dail. until you see as below.
2. You the open the oven door, there are 4 screw at the top (look up at front of the oevn), remove it, then you get as 2nd picture mm_chinching.jpgmm_chinching_0.jpg
May 18, 2010 | Frigidaire PLES389D Electric Kitchen Range
Number and temperature decals washed off my stove. I can't even remember right now if its a hotpoint or a frigidaire~ that washed away too!
you can find your model number behind the drawer
sometimes it is on the back side of the drawer front
hope this helps
but to asssure you both have repalceable mylar covers
Nov 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire PLES389DCC MODEL Electrolux Professional Series My glass cooktop is cracked, where is the cheapest site to find a replacement glass
318223626 - MAIN TOP
found it listed from 230.68 at prosupplyco.com
up to 281.85 at Repairclinic.com
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Frigidaire FEF366 Electric Kitchen Range
When turning on oven it says f3 or f13 err and i can erase it
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 06, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
