Question about Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS 2 OHM Car Audio Amplifier
CUR error on mrd-m605 amp
Alpine Type R bridged (Bridge wire: (-) to (+). Dual 2 ohm speaker
trintek
  • 111 Answers
SOURCE: Alpine MRV-1507 Running 2 Alpine Type R 1242D
If you are not using a capacitor at this point, i would recommend getting a 1 or 1.5 farad cap and adding it to the system to take some of the strain off of your electrical system.
next on the agenda is your speaker wiring, the mrv-1507 runs around 900 watts at 4 ohms bridged.. your speakers (I believe) have dual voice coils, so 4 connections total, if you are running 2 of the speakers this will be 8 connections total, in order to match the impedance of the amp you will have to wire the speakers in series/parallel. if you have never done this before, it is easy and will ensure you are running the set at 4 ohms (which will make a huge difference in and of itself).
take both speakers out, you are going to want to wire the positive from one coil to the negative of the other on the same speaker. do this to both of them, this should leave you with one positive and one negative unused on each speaker. now you want to hook both of your free negatives together and run it to the negative on your amp, then repeat the process with the positives.
this is going parallel (4 ohm / 2 coils = 2ohm) and series (2ohm x 2 bridged coils = 4ohm).
now your rms on the speakers is 500 watts each, so matching them to a 900 watt or so amp should work great.
when you are installing the wire, make sure the gauge is correct for the length of run and for the wattage, also connect your power directly to the battery or to a distribution block that is capable of handling the power. in all of my installations i run 0 gauge wire from the battery to a distributor block i mount on the firewall, then i run anywhere from 2 to 6 gauge wire to the amp depending on the wattage and run length.
for your purposes, if the length of wire from the battery to the amplifier is 13 feet or less, 4 gauge wire should be fine, if it is between 13 and 20 feet, i would consider buying 2 gauge wire for the install.
you didn't mention what size your fuse is, but i am going to assume it is 90-100 amp, for a 1000 watt amp i use a 150 amp fuse. if you can find a 130 amp fuse it should work fine.
a major thing to remember when installing an amplifier is that your vehicle's charging system was never meant to accommodate large loads for an extended period of time. connecting direct to the battery, using a stiffening capacitor, and properly matching impedance will go a long way towards helping to overcome the limitations. in the future, if you decide to go all out on this project, i would recommend getting a high output alternator, a battery isolator, and a deep cycle battery for the audio equipment. this will insure that you never kill your primary battery, and that you won't run into issues down the road with your vehicle electronics.
i hope this helps you out, if youhave any further questions, feel free to ask.
trin
Posted on Nov 15, 2007
  • 631 Answers
SOURCE: alpine amp mrd-m605
The amplifier probably has shorted output transistors. If the amp gives the same error message with the speaker wires disconnected from the amp, the amp needs to be repaired.
Posted on Dec 31, 2007
artbesio
  • 55 Answers
SOURCE: want to bridge my alpine 3555 amp to run my sub.
I'm assuming this atleast a 2 channel amplifier all you need to do is hook the negative side of the speaker wire coming from the sub to the negative channel one. and the positive to another positive on channel 2. Should indicate on your amplifier channel one and two. most amps provide a diagram right on the amplifier over top of the speaker inputs. let me know if this helps.
Posted on Mar 08, 2009
rteemon
  • 578 Answers
SOURCE: CUR on alpine MRD M 605
check your ground and make sure you battery power is connect properly
Posted on Jun 26, 2009
SOURCE: "cur" error mrd-m1005
u guys the cur stands for current witch means its starving for power so u could add a 2nd battery or upgrade ur alternator the battery doesent haved to be an expensive 1 just put a good strong batt in the trunk wire it in with ur wires u already have back there then run ur + and - straight off that batt and use atleast 4 guage trust what i say been in this game 10 yrs and this is how i feed 7 kids thanks
Posted on Feb 13, 2010
How do you get it out of cur mode
Hello whatup_132,
If the M605 fails and displays "CUR", it means that there is excessive current to the amp.
The most common causes for excessive current draw is operating the amp into a lower impedance than it is rated to handle, shorted speaker voice coil(s), and/or shorted or grounded speaker wires.
The amp can operate into a load no lower than 2ohms. First power everything off and disconnect the positive amp power lead temporarily (easist way is to just pull the fuse). At this point you should ONLY have the ground and remote connected. Reconnect positive (insert fuse) and turn on the vehicle ignition and your head unit. If the amp still displays the "CUR" error, the output MOSFET's are probably defective and the amp requires repair or replacement. If it powers up normally, reconnect the speaker wires until you locate the faulty one, and then correct whatever is causing it.
Hope this helps.
Jul 17, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
CUR display
Hello yte1771,
You can download the manual from Crutchfield.
The "CUR" display is an indication of excessive current and is most likely caused by too low impedance or a fault in the wiring or the amp itself. It's probably not your cap.
Hope this helps.
May 18, 2009 | Alpine MRD-M605 Car Audio Amplifier
Installing two amps
No, thats what you don't what to do. Even if you have 2 matching amps you don't do that. Every amp puts out different, and for 2 subs, you want to play at the the same time. If your only running 2 10's, I personal would just run the alpine (it's a mono amp made especially for subs) thats plenty for what you have. make sure you bridge them to get the full response. And your other amp i would use for your highs or mids, but run it @ stereo , which is 300 w @ 4 ohms. (Note: 600w @ 2ohms would be bridged and would play in Mono)
Building Competition stereo's is a big hobby of mine.
May 04, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Apr 14, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
CUR is showing on the display
The amp will reset when you cut the power off to it. Disconect bat for 30 sec and reconect. But to be honist with u if the wire jumped out and grounded some how during a high level, there is probley internal damage done.
Oct 17, 2008 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
CUR showing on the display
This means too much current, find and eliminate cause of excessie current and turn power off, also possibe power and ground are not big enough .Recommend 4guage wires
Oct 17, 2008 | Alpine MRD-M605 Car Audio Amplifier
Wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Jan 22, 2008 | Pioneer GM-X962 Car Audio Amplifier
Alpine amp mrd-m605
Dec 30, 2007 | Alpine MRD-M605 Car Audio Amplifier
Have you measured the DC resistance of the woofer to determine if it's OK? You will need to disconnect it from the amp. Check each voice coil individually.
If you disconnect both speaker wires from the amp, does it still show an overcurrent condition?
Oct 20, 2007 | Alpine MRD-M605 Car Audio Amplifier
Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS 2 OHM Car Audio Amplifier Logo
24 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
