Question about Canon BubbleJet i560 InkJet Printer
Can I go to grayscale all the time?
I have given up on the color cartridges in this printer and only want to use the black. Any color image prints in pink (magenta) only. Is there any way I can avoid having to select "grayscale" every time? Also, I am having problems with printing from one FileMaker database (others work fine). On other printers everything comes out black that is supposed to, but on this i560 it all prints pink. Selecting grayscale doesn't help in this case--it still prints pink! Any suggestions? Ann
    Genius:
  • 2,985 Answers
Usually 'black' or greyscale uses all colours to get a true black in many printers. Check you particular printer manual and soft ware to see if it allows for black/grey only. You could experiment [I don't know this particular printer] by putting black carts in all slots [If it is a chipped cart you may have to consider swapping the chips on the carts if removable. Some specialist ink firms[Lycos] do supply monochrome sets for certain printers - check them out. Also take a look at www.fixyourownprinter.com
Posted on May 19, 2007
SOURCE:
I have a lexmark x2470 printer.i would like to know whether it as one cartidge or two cartridges.please let me know if it is available in indaia
HI,
Please note that the #2 cartridge is the starter cartridge and the after market cartridge is the #1 cartridge.
The Lexmark X2470 printer uses the #1 cartridge which prints both color and black accordingly. While printing black it uses processed black. Hence, to print color images in "Black Only," please follow the steps given below:
1. Click on "Start," "All Programs," "Lexmark X2470 printer" group and then "Lexmark Photo Editor."
2. Click on "File" and then "Open" to select the color image file.
3. Click on "Image," "Mode" and then select "Grayscale."
4. Click on "Print."
This will print the image in gray.
Sep 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
I want to print in only black but my printer keeps telling me to install my color cartridge. How can I get my printer to work/print using only the black cartridge
You can print in only black and white by choosing the grayscale option in the print properties, but you still have to have ink in each of the color cartridges. Even if you are only printing black, the machine will not let you print if any of the colors are out.
Replace the empty ink cartridge, and then select "grayscale" to print only in black and white.
Jun 14, 2010 | HP PSC 750 All-In-One InkJet Printer
Is there any way to get my printer to print only black copies without having to buy the new color print cartridge
Go to the printer settings - Preferences- color tab - and select Grayscale in the color selection.
Once this is done, try print a color text and see if it comes in a gray scale. This will work.
To give you a tip on this.... understand that this printer has a black ink cartridge and a tri-color cartridge. When we select grayscale, only black cartridge would be used.
Good Luck.
Mar 15, 2010 | HP PhotoSmart C4180 All-in-One Color...
I want to use black ink only and stop wasting color ink
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
Feb 11, 2010 | Canon PIXMA MP470 All-in-One Printer
Color toner used up even though I selected grayscale
Selecting grayscale only will also make use of your color. when u select grayscale, look under the print options and select black cartridge only and for more economic printing, use fast draft or draft printing.
Jun 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark Z705
In the printing preferences you need to select Black and white.
1. open the document you want to print
2. click file
3. click print
4. select printer from list, then click on preferences
5. look around the pages.
In Color tab I found a print in Grayscale - this setting will print the document in black and white colors, the pages may be diffrent on diffrent printers. look for black and white setting or Grayscale.
picture: printing preferences, color page on a hp printer, select grayscale with black cartridge only.
May 19, 2009 | Lexmark Z705 Inkjet Printer
How can I print Black only?
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Canon BubbleJet i560 InkJet Printer Logo
155 people viewed this question
Clive
Clive
old marine
old marine
