Question about Asko D3531XLHDSS Stainless Steel Built-in Dishwasher
Asko dishwasher d3531 remove pump
Need to remove pump
SOURCE: Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Posted on Apr 11, 2009
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
  • 2976 Answers
SOURCE: Asko 1475 dishwasher - won't wash. Circulation pump?
Check your drain. It is dual purpose. It not only drains but, it also recirculates the water doring the cycles.
Posted on Aug 10, 2009
Macmarkus
  • 2605 Answers
SOURCE: How do I remove the cerculation pump
Hello, With the right technique it isn't too bad, but it does require removing it from the cabinet/cupboard. This is what I do. FIRST**Turn off the power at the main service panel or unplug the unit.** Shut off the water and undo the water supply and drain hose. Remove as much water from the sump well as possible because you'll need to lye the dishwasher on its front ( remove any dishes inside and also get some towels or a blanket to lay it on so you don't damage the front panel or control's ). Once you have the unit out and face down, you'll see the back of the circulation motor&pump assembly...this is where it gets a little tricky, but I've done plenty and will guide you through. The clamps holding the pump hoses in place are "one time" clamps so once removed they'll need to be replaced with narrow "worm gear" clamps when installing the new pump assy. Undo the wires at the side of the motor ( A good idea would be to take a picture or draw a diagram, the picture is likely better...in my case at least ). Hopefully from here you will get the new one in. Let me know how you make out, I'll watch your post. Good luck. Macmarkus :)
Posted on Apr 22, 2010
Testimonial: "Yhanks for the info now I need to decide new washer or fix rhis one any recomondations on a new one."
  • 867 Answers
SOURCE: asko D3120 remove door to clean
Depending on how thorough you are wanting to be depends on how far you want to dismantle the dishwasher, The outer door needs to be removed first, there are torx screws around the outside of the door which you need to remove and also 2 harder to spot ones at the bottom, The hinges are attached on the sides with another 2 torx screws each side but be careful as the hinges are under tension and can be a pain to align when putting back together.
Most of the time you don't need to remove the entire door to clean it but once the outer shell is off you can get to the front of the basepan where the dirt seems to gather around the lower door, A stiff bottle brush is good for cleaning this, Be very careful with the electronics and ensure you don't get any moisture near them, Also be careful with the wiring as due to exposure to heat the wires on this model can get brittle especially where the wires curve under the machine inside the plastic protective tube...
have fun.
Posted on Mar 04, 2012
Testimonial: "It was very helpful. Has confirmed that I won't go this far but work on the areas I can access without removing door. I thought it would be somewhat easier than this. Thank you."
How do I change the light bulb in the ASKO D3531 dishwasher?
Puzzled over this for a bit and finally pulled the dishwasher out from the cabinet. It's easy to replace the bulb from the outside. Socket is part of the wire guide which pops out with a screwdriver (see photo).
I can see threads on the inside dome but for the life of me I still can't get the dome to turn. Perhaps a special tool fitting the nubs would give one some leverage.
I replaced the 12v 5W halogen with a 12v 2.9W led assembly that has the same G4 base. Works well and should last longer than I will.
Nov 02, 2014 | Asko Dishwashers
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
Jun 08, 2011 | Asko D1976 Built-in Dishwasher
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Apr 22, 2011 | Asko D1976CSTM Built-in Dishwasher
Asko d3350 has the f2 flasing and pump just runs
sounds like you have a water leak. The machine is fitted with a leak detection device that runs the drain pump constantly as a safety mechanism. If you want to look your self you will need to pull the machine out and tilt it back and if possible remove the bottom panel, should be 4 screws, this gives you access to the components. If it doesn't come off then you will need to remove either 1 or both of the side panel, its just a number of screws holding them. Then see if you can see where the leak is coming from, you may need to order a new part. Hope this helps.
Mar 03, 2011 | Asko 24 in. D3350 Dishwasher
The pump on my ASKO 1716 dishwasher will not stop running. Previous to this it did not always pump out completely. Simple fix or big $$$?
Simple fix. It appears that your anti-flood feature has activated due to water pooling under the tub of the machine. You may be able to remove the water yourself or you may need help. If you want to try to remove it yourself you will need a syringe with a tube attached and you will have to get under the drum. Joe
Mar 25, 2010 | Asko D1716 Built-in Dishwasher
Aug 10, 2009 | Asko Dishwashers
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Jun 22, 2009 | Asko 1375 Dishwasher
Circ pump runs, but does not pump
Oppen the centre orifice , remove cover , remove impeller , clean debri and change impeler with new one, Vitally
May 13, 2009 | Asko 24 in. 1885 Built-in Dishwasher
Apr 04, 2008 | Asko Dishwashers
Asko D3531XLHDSS Stainless Steel Built-in Dishwasher Logo
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
